Aller au contenu principal
Hover-1 Charger Outer Shell Replacement
Ce dont vous avez besoin
  1. Hover-1 Charger Outer Shell Replacement, Outer Shell: étape 1, image 1 de 2 Hover-1 Charger Outer Shell Replacement, Outer Shell: étape 1, image 2 de 2
    • Flip the hoverboard over so that the warning label is facing up.
    • Remove the twelve 12 mm screws with a Phillips #2 screwdriver.
    • Remove the four 10 mm screws with a Phillips #2 screwdriver.
    • The screws nearest to the wheels may be hard to access. Be sure to use a long, thin screwdriver.
  2. Hover-1 Charger Outer Shell Replacement: étape 2, image 1 de 1
    • Pull the right cover away from the hoverboard.
  3. Hover-1 Charger Outer Shell Replacement: étape 3, image 1 de 2 Hover-1 Charger Outer Shell Replacement: étape 3, image 2 de 2
    • Unscrew four 12 mm screws that hold the right foot pad with a Philips #2 screwdriver.
    • Unscrew the four 18 mm screws with a Philips #2 screwdriver.
    • Use a long, thin screwdriver to access the two 12 mm screws nearest to the wheel.
  4. Hover-1 Charger Outer Shell Replacement: étape 4, image 1 de 2 Hover-1 Charger Outer Shell Replacement: étape 4, image 2 de 2
    • Unplug the battery by disconnecting the two pronged black and yellow cable.
  5. Hover-1 Charger Outer Shell Replacement: étape 5, image 1 de 3 Hover-1 Charger Outer Shell Replacement: étape 5, image 2 de 3 Hover-1 Charger Outer Shell Replacement: étape 5, image 3 de 3
    • Unplug the black, yellow, green and red four pin connector from the circuit board.
    • Unplug the red and black two pin connector from the circuit board.
  6. Hover-1 Charger Outer Shell Replacement: étape 6, image 1 de 2 Hover-1 Charger Outer Shell Replacement: étape 6, image 2 de 2
    • Thread the black, yellow, green, and red four pin connector through the opening to the left of the battery.
    • Remove the right foot pad from the hoverboard.
  7. Hover-1 Charger Outer Shell Replacement: étape 7, image 1 de 1
    • Pull the left cover away from the hoverboard.
  8. Hover-1 Charger Outer Shell Replacement: étape 8, image 1 de 2 Hover-1 Charger Outer Shell Replacement: étape 8, image 2 de 2
    • Unplug the red and white five pin connector from the circuit board.
    • Thread this connector through the middle cylinder.
    • Remove the right cover from the hoverboard.
  9. Hover-1 Charger Outer Shell Replacement: étape 9, image 1 de 2 Hover-1 Charger Outer Shell Replacement: étape 9, image 2 de 2
    • Unplug the red and white four pin connector from the speaker circuit board.
    • Unplug the blue and white three pin connector.
    • Unplug the blue and white two pin connector. This is photographed as an example.
  10. Hover-1 Charger Outer Shell Replacement: étape 10, image 1 de 1
    • Remove the left cover from the hoverboard.
  11. Hover-1 Charger Outer Shell Replacement: étape 11, image 1 de 2 Hover-1 Charger Outer Shell Replacement: étape 11, image 2 de 2
    • Disconnect the two pronged black and yellow cable.
  12. Hover-1 Charger Outer Shell Replacement: étape 12, image 1 de 3 Hover-1 Charger Outer Shell Replacement: étape 12, image 2 de 3 Hover-1 Charger Outer Shell Replacement: étape 12, image 3 de 3
    • Remove three black and red two pin connectors from the left circuit board.
    • Remove the red, yellow, and black three pin connector.
    • Remove zip tie if present.
  13. Hover-1 Charger Outer Shell Replacement: étape 13, image 1 de 1
    • Unscrew four 12 mm screws from the sides holding the left foot pad with a Phillips #2 screwdriver.
    • Unscrew four 18 mm screws with a Phillips #2 screwdriver.
  14. Hover-1 Charger Outer Shell Replacement: étape 14, image 1 de 1
    • Remove the left foot pad from the hoverboard.
Mark Rapiz
Membre depuis le 10/10/19
229 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team S12-G1, Regan Fall 2019 Membre de l'équipe Cal Poly, Team S12-G1, Regan Fall 2019
CPSU-REGAN-F19S12G1
4 membres
6 tutoriels rédigés
Un commentaire
Where do I buy the shell their website doesnt have it
firestineanthony - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 4
Total : 505
