Aller au contenu principal
Hover-1 Chrome Battery Replacement
Ce dont vous avez besoin
  1. Hover-1 Chrome Battery Replacement, Hover-1 Chrome Disassembly: étape 1, image 1 de 1
    • Flip the Hover-1 Chrome upside down.
    • Use a Phillips #2 screwdriver to remove the fourteen 14 mm screws from the bottom of the Hover-1.
    • Break the two black tape circles, and remove the two 15 mm Phillips screws underneath.
  2. Hover-1 Chrome Battery Replacement: étape 2, image 1 de 1
    • Lift the shell without the speaker grille and unplug the battery.
  3. Hover-1 Chrome Battery Replacement: étape 3, image 1 de 2 Hover-1 Chrome Battery Replacement: étape 3, image 2 de 2
    • Lift the shell with the speaker grille.
    • Unplug the speaker.
    • Unplug the LEDs.
    • Unplug the power button
    • Unplug the charging port.
  4. Hover-1 Chrome Battery Replacement, Battery: étape 4, image 1 de 1
    • Place the metal spudger end between the blue battery and the adhesive pad that attaches it to the metal body.
    • Use the metal spudger only as a last resort if the adhesive is too strong for either your hands or other plastic prying tools.
    • Use the spudger to pry the battery loose from the adhesive.
  5. Hover-1 Chrome Battery Replacement: étape 5, image 1 de 2 Hover-1 Chrome Battery Replacement: étape 5, image 2 de 2
    • Pull and wiggle the battery completely off of the adhesive using your hands.
    • Remove the battery from the body.
Nick McGuire
Membre depuis le 10/08/18
551 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team S4-G1, White Fall 2018 Membre de l'équipe Cal Poly, Team S4-G1, White Fall 2018
CPSU-WHITE-F18S4G1
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 14
Total : 674
