Aller au contenu principal
Hover-1 Chrome Outer Shell Replacement
Ce dont vous avez besoin
  1. Hover-1 Chrome Outer Shell Replacement, Hover-1 Chrome Disassembly: étape 1, image 1 de 1
    • Flip the Hover-1 Chrome upside down.
    • Use a Phillips #2 screwdriver to remove the fourteen 14 mm screws from the bottom of the Hover-1.
    • Break the two black tape circles, and remove the two 15 mm Phillips screws underneath.
  2. Hover-1 Chrome Outer Shell Replacement: étape 2, image 1 de 1
    • Lift the shell without the speaker grille and unplug the battery.
  3. Hover-1 Chrome Outer Shell Replacement: étape 3, image 1 de 2 Hover-1 Chrome Outer Shell Replacement: étape 3, image 2 de 2
    • Lift the shell with the speaker grille.
    • Unplug the speaker.
    • Unplug the LEDs.
    • Unplug the power button
    • Unplug the charging port.
  4. Hover-1 Chrome Outer Shell Replacement, Outer Shell: étape 4, image 1 de 1
    • Remove the twelve 14 mm Phillips #2 screws holding the top shell on.
    • The other six screws are on the side without the battery.
  5. Hover-1 Chrome Outer Shell Replacement: étape 5, image 1 de 3 Hover-1 Chrome Outer Shell Replacement: étape 5, image 2 de 3 Hover-1 Chrome Outer Shell Replacement: étape 5, image 3 de 3
    • Free the cables held atop the bracket holding the battery in place.
    • Remove the four 14 mm Phillips #2 screws holding the battery bracket in place.
    • Pull the battery bracket free.
  6. Hover-1 Chrome Outer Shell Replacement: étape 6, image 1 de 1
    • Unplug the cords for the top LEDs.
    • The other side of the board is structurally symmetrical. However instead of going under the battery bracket, these cords go through a zip tie. These cables must be removed from the zip tie in order to continue.
  7. Hover-1 Chrome Outer Shell Replacement: étape 7, image 1 de 1
    • Turn the board over and pull the top panel off.
Ligne d'arrivée
Dylan Prins
Membre depuis le 10/08/18
212 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team S4-G1, White Fall 2018 Membre de l'équipe Cal Poly, Team S4-G1, White Fall 2018
CPSU-WHITE-F18S4G1
4 membres
6 tutoriels rédigés
Un commentaire
Where can i get a replacement shell?
born4roblox - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 13
Total : 342
