Aller au contenu principal
Hover-1 Folding E-Scooter LED Headlight Replacement
Ce dont vous avez besoin
  1. Hover-1 Folding E-Scooter LED Headlight Replacement, LED Headlight: étape 1, image 1 de 2 Hover-1 Folding E-Scooter LED Headlight Replacement, LED Headlight: étape 1, image 2 de 2
    • Face the front of the scooter towards you.
    • Remove all four 24mm bolts by turning counterclockwise using the Hex 4 screwdriver bit.
  2. Hover-1 Folding E-Scooter LED Headlight Replacement: étape 2, image 1 de 2 Hover-1 Folding E-Scooter LED Headlight Replacement: étape 2, image 2 de 2
    • Remove the headlight housing.
    • The LED should release when you take off the cover.
    • Be careful when taking off the cover; the light is glued onto the cover and could harm the device.
  3. Hover-1 Folding E-Scooter LED Headlight Replacement: étape 3, image 1 de 2 Hover-1 Folding E-Scooter LED Headlight Replacement: étape 3, image 2 de 2
    • Disconnect the red wire using a soldering iron.
    • The soldering iron should melt the glue for you, so don't worry about removing it yourself.
  4. Hover-1 Folding E-Scooter LED Headlight Replacement: étape 4, image 1 de 1
    • For ease of installation, tin your new LED and the connecting wire with the soldering iron and solder.
    • Solder your new light on to the existing red wire.
    • For help on how to solder, refer to iFixit's Soldering Guide.
To reassemble your device, follow these instructions in reverse order with the new LED.
Nicolo DiFronzo
Membre depuis le 10/08/18
229 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team S15-G5, White Fall 2018 Membre de l'équipe Cal Poly, Team S15-G5, White Fall 2018
CPSU-WHITE-F18S15G5
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 12
30 derniers jours : 26
Total : 3,150
