Introduction
Replacing in the battery in your Hover-1 H1 hoverboard might help to solve charging problems.
Outils
Pièces
Aucune pièce spécifiée.
Remove the ten 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
Remove the twelve 9mm sheet metal screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
Remove the four 7mm screws by using a Phillips #2 screwdriver to rotate the screws counterclockwise.
