Aller au contenu principal
Hover-1 H1 Battery Replacement
Ce dont vous avez besoin
  1. Hover-1 H1 Battery Replacement, Bottom Shell: étape 1, image 1 de 1
    • Remove the ten 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
    • Remove the twelve 9mm sheet metal screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
  2. Hover-1 H1 Battery Replacement: étape 2, image 1 de 1
    • Puncture the two black stickers by using the tip of a screwdriver.
    • Remove the two 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
  3. Hover-1 H1 Battery Replacement: étape 3, image 1 de 2 Hover-1 H1 Battery Replacement: étape 3, image 2 de 2
    • Lift each side of the bottom shell by pulling up.
    • When lifting the shell, take care to not tear any cables from their connectors.
  4. Hover-1 H1 Battery Replacement: étape 4, image 1 de 1
    • Unplug the battery by pulling gently on both sides of the orange connector.
  5. Hover-1 H1 Battery Replacement, Battery: étape 5, image 1 de 1
    • Remove the four 7mm screws by using a Phillips #2 screwdriver to rotate the screws counterclockwise.
  6. Hover-1 H1 Battery Replacement: étape 6, image 1 de 1
    • Gently lift the battery harness and remove the battery by lifting the battery and moving it away from the hoverboard.
4 autres ont terminé cette réparation.
Aaron Teh
Membre depuis le 10/08/18
442 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team S17-G6, White Fall 2018 Membre de l'équipe Cal Poly, Team S17-G6, White Fall 2018
CPSU-WHITE-F18S17G6
4 membres
9 tutoriels rédigés
15 commentaires de tutoriel
The stickers were the trick. I didn’t see them!
Daniel D - Réponse
After removing the 4 screws that is holding the battery in place I still can't remove the battery. I tried gently to pry under the battery but it doesn't budge. Uni Sun model HY-A01B. How do I solve this problem?
Terry Pollard - Réponse
Where do I get another battery to replace it???
Tony Pate - Réponse
That's the question I can't seem to find the answer to
Darin -
Very low quality. Bought for my son who haven’t even used it for 15 times. Got it during winter and before summer the product stopped working.
tosin3in1 - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 9
7 derniers jours : 40
30 derniers jours : 180
Total : 11,114
