Aller au contenu principal
Hover-1 H1 Charging Port Replacement
Ce dont vous avez besoin
  1. Hover-1 H1 Charging Port Replacement, Bottom Shell: étape 1, image 1 de 1
    • Remove the ten 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
    • Remove the twelve 9mm sheet metal screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
  2. Hover-1 H1 Charging Port Replacement: étape 2, image 1 de 1
    • Puncture the two black stickers by using the tip of a screwdriver.
    • Remove the two 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
  3. Hover-1 H1 Charging Port Replacement: étape 3, image 1 de 2 Hover-1 H1 Charging Port Replacement: étape 3, image 2 de 2
    • Lift each side of the bottom shell by pulling up.
    • When lifting the shell, take care to not tear any cables from their connectors.
  4. Hover-1 H1 Charging Port Replacement: étape 4, image 1 de 1
    • Unplug the battery by pulling gently on both sides of the orange connector.
  5. Hover-1 H1 Charging Port Replacement, Charging Port: étape 5, image 1 de 2 Hover-1 H1 Charging Port Replacement, Charging Port: étape 5, image 2 de 2
    • Using a utility knife, scratch off the hot glue from the connector attaching the red and black wires to the motherboard.
    • Be careful to not damage the wires or connector when removing the glue.
  6. Hover-1 H1 Charging Port Replacement: étape 6, image 1 de 1
    • Remove the charging port connector from the motherboard by squeezing the connector and pulling the connector up.
  7. Hover-1 H1 Charging Port Replacement: étape 7, image 1 de 2 Hover-1 H1 Charging Port Replacement: étape 7, image 2 de 2
    • Using an adjustable wrench, unscrew the nut that is attaching the charging port to the bottom shell.
    • It might be helpful to put the charger in the charging port while unscrewing the nut to ensure that the port is not spinning.
  8. Hover-1 H1 Charging Port Replacement: étape 8, image 1 de 2 Hover-1 H1 Charging Port Replacement: étape 8, image 2 de 2
    • Pull the charging port to the left through the shell.
Madeline David
Membre depuis le 10/08/18
280 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team S17-G6, White Fall 2018 Membre de l'équipe Cal Poly, Team S17-G6, White Fall 2018
CPSU-WHITE-F18S17G6
4 membres
7 tutoriels rédigés
Un commentaire
I need to replace the charging port on my H1 hoverboard. Can you share the link for the actual replacement part.
prdrngga - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 11
30 derniers jours : 58
Total : 3,924
