Aller au contenu principal
Hover-1 H1 LED Headlight Replacement
Ce dont vous avez besoin
  1. Hover-1 H1 LED Headlight Replacement, Bottom Shell: étape 1, image 1 de 1
    • Remove the ten 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
    • Remove the twelve 9mm sheet metal screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
  2. Hover-1 H1 LED Headlight Replacement: étape 2, image 1 de 1
    • Puncture the two black stickers by using the tip of a screwdriver.
    • Remove the two 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
  3. Hover-1 H1 LED Headlight Replacement: étape 3, image 1 de 2 Hover-1 H1 LED Headlight Replacement: étape 3, image 2 de 2
    • Lift each side of the bottom shell by pulling up.
    • When lifting the shell, take care to not tear any cables from their connectors.
  4. Hover-1 H1 LED Headlight Replacement: étape 4, image 1 de 1
    • Unplug the battery by pulling gently on both sides of the orange connector.
  5. Hover-1 H1 LED Headlight Replacement, LED Headlights: étape 5, image 1 de 1
    • Unplug the lights from the battery by pulling gently on both sides of the black connector attached to the white wires.
  6. Hover-1 H1 LED Headlight Replacement: étape 6, image 1 de 1
    • Remove the vertical light from the shell by using your hands to pull it free from the surrounding shell.
  7. Hover-1 H1 LED Headlight Replacement: étape 7, image 1 de 1
    • Remove two 8mm screws using a Phillips #0 screwdriver to rotate the screws counterclockwise.
    • Remove the horizontal light by using your fingers to pull the light up out of the shell.
Sara Passantino
Membre depuis le 10/08/18
347 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team S17-G6, White Fall 2018 Membre de l'équipe Cal Poly, Team S17-G6, White Fall 2018
CPSU-WHITE-F18S17G6
4 membres
9 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 5
Total : 1,418
