Introduction
This guide explains how to replace the LED headlights on your Hover-1 H1 hoverboard.
Outils
Pièces
Aucune pièce spécifiée.
Remove the ten 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
Remove the twelve 9mm sheet metal screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
Unplug the lights from the battery by pulling gently on both sides of the black connector attached to the white wires.
