Aller au contenu principal
Hover-1 Horizon Left Gyroscope Sensor Board Replacement
Ce dont vous avez besoin
  1. Hover-1 Horizon Left Gyroscope Sensor Board Replacement, Base Plate: étape 1, image 1 de 2 Hover-1 Horizon Left Gyroscope Sensor Board Replacement, Base Plate: étape 1, image 2 de 2
    • Remove the six 12mm Phillips #2 screws holding the base plate.
  2. Hover-1 Horizon Left Gyroscope Sensor Board Replacement: étape 2, image 1 de 2 Hover-1 Horizon Left Gyroscope Sensor Board Replacement: étape 2, image 2 de 2
    • Remove the two 11mm Phillips #1 screws that hold the base plate to the body.
  3. Hover-1 Horizon Left Gyroscope Sensor Board Replacement: étape 3, image 1 de 3 Hover-1 Horizon Left Gyroscope Sensor Board Replacement: étape 3, image 2 de 3 Hover-1 Horizon Left Gyroscope Sensor Board Replacement: étape 3, image 3 de 3
    • Remove the base plate by lifting it up.
    • The base plate is connected to the body with wires. The wires are long enough to set the base plate to the side.
  4. Hover-1 Horizon Left Gyroscope Sensor Board Replacement, Left Gyroscope Sensor Board: étape 4, image 1 de 3 Hover-1 Horizon Left Gyroscope Sensor Board Replacement, Left Gyroscope Sensor Board: étape 4, image 2 de 3 Hover-1 Horizon Left Gyroscope Sensor Board Replacement, Left Gyroscope Sensor Board: étape 4, image 3 de 3
    • Remove the two connectors on either side of the board by lifting the tab and pulling out.
    • Remove the connector in the middle of the board by squeezing the tab and pulling up.
  5. Hover-1 Horizon Left Gyroscope Sensor Board Replacement: étape 5, image 1 de 2 Hover-1 Horizon Left Gyroscope Sensor Board Replacement: étape 5, image 2 de 2
    • Remove the four 11mm Phillips #1 screws that hold the cover on.
  6. Hover-1 Horizon Left Gyroscope Sensor Board Replacement: étape 6, image 1 de 3 Hover-1 Horizon Left Gyroscope Sensor Board Replacement: étape 6, image 2 de 3 Hover-1 Horizon Left Gyroscope Sensor Board Replacement: étape 6, image 3 de 3
    • Remove the four 11mm Phillips #1 screws that attach the gyroscope board to the mount.
    • Lift the board to reveal the connections on the bottom.
  7. Hover-1 Horizon Left Gyroscope Sensor Board Replacement: étape 7, image 1 de 2 Hover-1 Horizon Left Gyroscope Sensor Board Replacement: étape 7, image 2 de 2
    • Remove the middle connector by squeezing the top of the tab and pulling up.
  8. Hover-1 Horizon Left Gyroscope Sensor Board Replacement: étape 8, image 1 de 3 Hover-1 Horizon Left Gyroscope Sensor Board Replacement: étape 8, image 2 de 3 Hover-1 Horizon Left Gyroscope Sensor Board Replacement: étape 8, image 3 de 3
    • Remove the four 12mm Phillips #2 screws that hold the motherboard to the base.
    • Pull the motherboard away from the gyroscope by grabbing it with two hands and pulling it to the right .
  9. Hover-1 Horizon Left Gyroscope Sensor Board Replacement: étape 9, image 1 de 3 Hover-1 Horizon Left Gyroscope Sensor Board Replacement: étape 9, image 2 de 3 Hover-1 Horizon Left Gyroscope Sensor Board Replacement: étape 9, image 3 de 3
    • Unclip the black connector by squeezing both sides and pulling them apart.
Casey Winans
Membre depuis le 10/08/18
324 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team S13-G6, White Fall 2018 Membre de l'équipe Cal Poly, Team S13-G6, White Fall 2018
CPSU-WHITE-F18S13G6
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 27
30 derniers jours : 121
Total : 3,875
