Aller au contenu principal
Hover-1 Liberty Bottom Cover Replacement
Ce dont vous avez besoin
  1. Hover-1 Liberty Bottom Cover Replacement, Bottom Cover: étape 1, image 1 de 2 Hover-1 Liberty Bottom Cover Replacement, Bottom Cover: étape 1, image 2 de 2
    • Flip the hoverboard over so the labels are facing upwards.
    • Remove the twenty 18mm screws using a Phillips #2 screwdriver and twisting counterclockwise.
  2. Hover-1 Liberty Bottom Cover Replacement: étape 2, image 1 de 2 Hover-1 Liberty Bottom Cover Replacement: étape 2, image 2 de 2
    • Remove the bottom cover by lifting it away from the hoverboard.
    • The cover on the side without the battery has two wires connecting the power button and charging port.
  3. Hover-1 Liberty Bottom Cover Replacement: étape 3, image 1 de 3 Hover-1 Liberty Bottom Cover Replacement: étape 3, image 2 de 3 Hover-1 Liberty Bottom Cover Replacement: étape 3, image 3 de 3
    • Remove one connector from the non-battery side circuit board.
    • Remove the next connector from the non-battery side circuit board.
    • To remove the connectors, pinch the plug and pull away from the circuit board.
2 autres ont terminé cette réparation.
Patrick Bacon
Membre depuis le 10/08/18
411 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team S13-G2, White Fall 2018 Membre de l'équipe Cal Poly, Team S13-G2, White Fall 2018
CPSU-WHITE-F18S13G2
3 membres
4 tutoriels rédigés
2 commentaires
I'm gettin nothin at all.. Charger is green.. But absolutely nothing when press the on button.. All the cables are connected.. No lights or anythin.. Can anyone help.
stemirnoff@hotmail.co.uk - Réponse
I am getting the 5 red lights. I have followed all the instructions. Is there a site to buy the motherboards that are burned out? Is it financially worth buy both boards and replacing them?
-Christopher Fields, Network Engineer, PC Repair, Grantsville, UT
Christopher Fields - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 8
30 derniers jours : 24
Total : 3,070
