Aller au contenu principal
Hover-1 Liberty Gyroscope Sensor Boards Replacement
Ce dont vous avez besoin
  1. Hover-1 Liberty Gyroscope Sensor Boards Replacement, Bottom Cover: étape 1, image 1 de 2 Hover-1 Liberty Gyroscope Sensor Boards Replacement, Bottom Cover: étape 1, image 2 de 2
    • Flip the hoverboard over so the labels are facing upwards.
    • Remove the twenty 18mm screws using a Phillips #2 screwdriver and twisting counterclockwise.
  2. Hover-1 Liberty Gyroscope Sensor Boards Replacement: étape 2, image 1 de 2 Hover-1 Liberty Gyroscope Sensor Boards Replacement: étape 2, image 2 de 2
    • Remove the bottom cover by lifting it away from the hoverboard.
    • The cover on the side without the battery has two wires connecting the power button and charging port.
  3. Hover-1 Liberty Gyroscope Sensor Boards Replacement: étape 3, image 1 de 3 Hover-1 Liberty Gyroscope Sensor Boards Replacement: étape 3, image 2 de 3 Hover-1 Liberty Gyroscope Sensor Boards Replacement: étape 3, image 3 de 3
    • Remove one connector from the non-battery side circuit board.
    • Remove the next connector from the non-battery side circuit board.
    • To remove the connectors, pinch the plug and pull away from the circuit board.
  4. Hover-1 Liberty Gyroscope Sensor Boards Replacement, Gyroscope Sensor Boards: étape 4, image 1 de 1
    • Place the hoverboard so the sensor boards face you.
  5. Hover-1 Liberty Gyroscope Sensor Boards Replacement: étape 5, image 1 de 2 Hover-1 Liberty Gyroscope Sensor Boards Replacement: étape 5, image 2 de 2
    • Remove battery connector by pulling it apart.
    • Slide the rubber sheaths away from the connector on the blue, green, and yellow wires.
    • Disconnect the colored wires by pulling them apart.
    • The large colored wires connecting the sensor boards to the wheels need to match for the motor to operate correctly.
  6. Hover-1 Liberty Gyroscope Sensor Boards Replacement: étape 6, image 1 de 2 Hover-1 Liberty Gyroscope Sensor Boards Replacement: étape 6, image 2 de 2
    • Remove the white cable from the sensor boards by disconnecting the cable on each side of the hoverboard.
    • To release the cable connector, squeeze the sides while pulling it away from the sensor board.
  7. Hover-1 Liberty Gyroscope Sensor Boards Replacement: étape 7, image 1 de 2 Hover-1 Liberty Gyroscope Sensor Boards Replacement: étape 7, image 2 de 2
    • Remove the four 10mm screws with a Phillips #1 screwdriver.
  8. Hover-1 Liberty Gyroscope Sensor Boards Replacement: étape 8, image 1 de 2 Hover-1 Liberty Gyroscope Sensor Boards Replacement: étape 8, image 2 de 2
    • Remove the sensor board by lifting it away from the hoverboard.
    • Repeat steps 4-8 to remove the sensor board from the other side.
6 autres ont terminé cette réparation.
Eduardo Miranda
Membre depuis le 10/08/18
355 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team S13-G2, White Fall 2018 Membre de l'équipe Cal Poly, Team S13-G2, White Fall 2018
CPSU-WHITE-F18S13G2
3 membres
4 tutoriels rédigés
9 commentaires de tutoriel
Where can you purchase the replacement board for the Hover-1 liberty?
Clifton Hale - Réponse
Where do you get replacement board?
Tim Sole - Réponse
After riding just a few times the hover board wouldn’t move. Also it has a rattle inside
Regina - Réponse
Make this site useful by telling us where we can buy a new circuit board.
tim stoinski - Réponse
Where do you get circuit board from.
markrichardowen - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 41
Total : 9,755
