Aller au contenu principal
Hover-1 Matrix Pad Replacement
Ce dont vous avez besoin
  1. Hover-1 Matrix Pad Replacement, Pad: étape 1, image 1 de 2 Hover-1 Matrix Pad Replacement, Pad: étape 1, image 2 de 2
    • Remove the screws on the back of the hoverboard using a Phillips #1 screwdriver.
    • Remove the back shell from the hoverboard.
  2. Hover-1 Matrix Pad Replacement: étape 2, image 1 de 1
    • Remove the screws from the metal layer inside the hoverboard using a Phillips #1 screwdriver.
  3. Hover-1 Matrix Pad Replacement: étape 3, image 1 de 1
    • Separate the upper shell of the hoverboard and the metal layer inside.
  4. Hover-1 Matrix Pad Replacement: étape 4, image 1 de 2 Hover-1 Matrix Pad Replacement: étape 4, image 2 de 2
    • Start by identifying the motherboard, which is the green pad shown in the picture.
    • Remove the screws on the corners of the motherboard with the Phillips #1 screwdriver and take it off.
    • There are cables attached to the motherboard so go ahead and unattach them.
  5. Hover-1 Matrix Pad Replacement: étape 5, image 1 de 3 Hover-1 Matrix Pad Replacement: étape 5, image 2 de 3 Hover-1 Matrix Pad Replacement: étape 5, image 3 de 3
    • Use picture 1 as a guide and move the motherboard to the other side.
    • Identify the two black rubber buttons that are shown in the second picture.
    • Remove the two rubber buttons using the Phillips #1 screwdriver.
  6. Hover-1 Matrix Pad Replacement: étape 6, image 1 de 1
    • Removing the rubber buttons in the previous step allows you to take the pad off.
    • Finally, take off the old pad and put on a new pad.
To reassemble your device, follow these instructions starting with step number 6 and finishing with step number 1.
Jici Zhuang
Membre depuis le 10/22/18
362 Réputation
2 tutoriels rédigés
Équipe
UC Davis, Team S7-G2, Lore Fall 2018 Membre de l'équipe UC Davis, Team S7-G2, Lore Fall 2018
UCD-LORE-F18S7G2
3 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 7
Total : 338
