Aller au contenu principal
Hover-1 Maverick Battery Replacement
Ce dont vous avez besoin
  1. Hover-1 Maverick Battery Replacement, Battery: étape 1, image 1 de 2 Hover-1 Maverick Battery Replacement, Battery: étape 1, image 2 de 2
    • Remove the twenty 15mm Phillips #1 screws from the shell of the hoverboard.
    • Remove the shell.
  2. Hover-1 Maverick Battery Replacement: étape 2, image 1 de 3 Hover-1 Maverick Battery Replacement: étape 2, image 2 de 3 Hover-1 Maverick Battery Replacement: étape 2, image 3 de 3
    • Remove the four 8mm Phillips #1 screws holding down the black plastic casing.
    • Lift off the black plastic retaining bracket.
  3. Hover-1 Maverick Battery Replacement: étape 3, image 1 de 2 Hover-1 Maverick Battery Replacement: étape 3, image 2 de 2
    • Pull the battery upward lightly to remove from the device.
    • The battery is secured to the device with adhesive tape.
Piper Feldman
Membre depuis le 01/23/20
409 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team S2-G2, White Winter 2020 Membre de l'équipe Cal Poly, Team S2-G2, White Winter 2020
CPSU-WHITE-W20S2G2
2 membres
4 tutoriels rédigés
2 commentaires
What voltage should the battery put out? Mines is 30v, charger is green at the wall but still the board won’t turn on
Barry Rogers - Réponse
Where can I find that same battery i cant find one
Toad Blue - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 12
30 derniers jours : 84
Total : 2,877
