Aller au contenu principal
Hover-1 Maverick Motor Wheel Replacement
Ce dont vous avez besoin
  1. Hover-1 Maverick Motor Wheel Replacement, Motherboard: étape 1, image 1 de 3 Hover-1 Maverick Motor Wheel Replacement, Motherboard: étape 1, image 2 de 3 Hover-1 Maverick Motor Wheel Replacement, Motherboard: étape 1, image 3 de 3
    • Remove the twenty 15mm Phillips #1 screws from the shell of the hoverboard.
    • Open the shell.
    • There is one motherboard on each side of the device located near the wheels.
  2. Hover-1 Maverick Motor Wheel Replacement: étape 2, image 1 de 2 Hover-1 Maverick Motor Wheel Replacement: étape 2, image 2 de 2
    • Disconnect the battery to prevent any electrical currents from coming through the wires.
  3. Hover-1 Maverick Motor Wheel Replacement: étape 3, image 1 de 2 Hover-1 Maverick Motor Wheel Replacement: étape 3, image 2 de 2
    • Squeeze and pull on the wires to detach them from the motherboard.
  4. Hover-1 Maverick Motor Wheel Replacement: étape 4, image 1 de 2 Hover-1 Maverick Motor Wheel Replacement: étape 4, image 2 de 2
    • Remove the four 8mm Phillips #1 screws.
    • Remove the motherboard from the device.
    • Repeat for the other motherboard.
  5. Hover-1 Maverick Motor Wheel Replacement, Motor: étape 5, image 1 de 2 Hover-1 Maverick Motor Wheel Replacement, Motor: étape 5, image 2 de 2
    • After the motherboard is removed from either side, remove the four 15 mm hex screws with a 5mm Allen wrench.
    • Remove the metal covering from over the motor.
  6. Hover-1 Maverick Motor Wheel Replacement: étape 6, image 1 de 1
    • The motor is attached to the wheel, so in order to remove the motor, you must take out the entire wheel.
Piper Feldman
Membre depuis le 01/23/20
409 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team S2-G2, White Winter 2020 Membre de l'équipe Cal Poly, Team S2-G2, White Winter 2020
CPSU-WHITE-W20S2G2
2 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 13
Total : 468
