Aller au contenu principal
Hover-1 Nomad Battery Replacement
Ce dont vous avez besoin
  1. Hover-1 Nomad Battery Replacement, Outer Shell: étape 1, image 1 de 3 Hover-1 Nomad Battery Replacement, Outer Shell: étape 1, image 2 de 3 Hover-1 Nomad Battery Replacement, Outer Shell: étape 1, image 3 de 3
    • Break the two warranty stickers by poking a screwdriver through them or peeling them off.
    • Remove the following twenty screws by rotating the screwdriver counterclockwise:
    • Eight 16.2mm Phillips #2 screws
    • Eight 15mm Phillips #2 screws
    • Four 19.1mm Phillips #2 screws
    • The holes containing most of the screws are deep and narrow. A screwdriver with interchangable bits will not be able to reach them.
    • Do not over-tighten the screws during reassembly. Over-tightened screws can crack the plastic channels holding the shell to the frame of the hoverboard.
  2. Hover-1 Nomad Battery Replacement: étape 2, image 1 de 3 Hover-1 Nomad Battery Replacement: étape 2, image 2 de 3 Hover-1 Nomad Battery Replacement: étape 2, image 3 de 3
    • Use a nylon spudger to pry the metal handle away from the outer shell.
    • Rotate the metal handle toward the center of the hoverboard to unlock the plate from the retaining clips.
    • Lift the hoverboard off the metal handle.
    • Repeat for the handle on the other side of the hoverboard.
  3. Hover-1 Nomad Battery Replacement: étape 3, image 1 de 1
    • Lift the plastic cover on each side up and away from the device.
    • Multiple wires connect the circuit boards to the outer shell. Remove the shell gently to avoid damaging the wires or components.
  4. Hover-1 Nomad Battery Replacement: étape 4, image 1 de 2 Hover-1 Nomad Battery Replacement: étape 4, image 2 de 2
    • Disconnect the following wires by pinching the connector tabs and pulling the plugs out of the connectors:
    • Charging port wires
    • Speaker assembly wires
    • Power button wires
    • Headlight wires
    • Only the headlight wires need to be disconnected from the other circuit board.
    • Ensure the wires are connected to the correct ports on the circuit board during reassembly.
  5. Hover-1 Nomad Battery Replacement, Gyroscope Sensor Boards: étape 5, image 1 de 1
    • Cut the two zip ties around the bundle of wires with cutting pliers.
    • The zip tie is secured tightly around the wires. Be careful not to nick or cut any of the wires while removing the zip tie.
    • Do not puncture or cut the lithium-ion battery. Especially with a battery this large, the battery can catch fire or explode if damaged.
  6. Hover-1 Nomad Battery Replacement: étape 6, image 1 de 2 Hover-1 Nomad Battery Replacement: étape 6, image 2 de 2
    • Disconnect the circuit boards from the battery by pulling both battery connectors apart.
  7. Hover-1 Nomad Battery Replacement: étape 7, image 1 de 3 Hover-1 Nomad Battery Replacement: étape 7, image 2 de 3 Hover-1 Nomad Battery Replacement: étape 7, image 3 de 3
    • Disconnect the following wires connecting the circuit boards to the sensors and motors:
    • Disconnect the white connectors by pinching the tab and pulling up on the connectors.
    • Disconnect the black connectors by pulling the two sides apart.
    • Disconnect the green, yellow, and blue cables by pulling back the plastic shielding and pulling the ends apart.
  8. Hover-1 Nomad Battery Replacement: étape 8, image 1 de 1
    • Remove the four 14mm Phillips #1 screws in the corners of each circuit board by turning the screwdriver counterclockwise.
  9. Hover-1 Nomad Battery Replacement: étape 9, image 1 de 1
    • Remove the circuit board by pulling it up and out of the hoverboard.
  10. Hover-1 Nomad Battery Replacement, Battery: étape 10, image 1 de 2 Hover-1 Nomad Battery Replacement, Battery: étape 10, image 2 de 2
    • Remove the four 15mm screws from the battery cage with a Phillips #2 screwdriver.
  11. Hover-1 Nomad Battery Replacement: étape 11, image 1 de 2 Hover-1 Nomad Battery Replacement: étape 11, image 2 de 2
    • Lift the battery cage up and off the battery.
  12. Hover-1 Nomad Battery Replacement: étape 12, image 1 de 1
    • Remove the battery by lifting it off the hoverboard frame.
    • The battery is attached to the frame with an adhesive strip. It can be removed by hand with some force.
Samuel Frazee
Membre depuis le 10/08/18
1 015 Réputation
7 tutoriels rédigés
Équipe
Cal Poly, Team S15-G1, White Fall 2018 Membre de l'équipe Cal Poly, Team S15-G1, White Fall 2018
CPSU-WHITE-F18S15G1
4 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 4
Total : 1,127
