Aller au contenu principal
Hover-1 Rally Brake Pad Replacement
Ce dont vous avez besoin
  1. Hover-1 Rally Brake Pad Replacement, Rear Wheel: étape 1, image 1 de 1
    • Remove the 4 mm screw in center of the wheel with a 4 mm hex key.
    • Flip the scooter and remove the same size screw from the opposite side of the wheel.
  2. Hover-1 Rally Brake Pad Replacement: étape 2, image 1 de 1
    • Slide the plastic side piece off from both sides of the scooter.
    • Two 4 mm screws and 2 side panels are taken out.
  3. Hover-1 Rally Brake Pad Replacement: étape 3, image 1 de 2 Hover-1 Rally Brake Pad Replacement: étape 3, image 2 de 2
    • Use a 4 mm bit extension to push the axle out of the wheel’s center.
  4. Hover-1 Rally Brake Pad Replacement: étape 4, image 1 de 1
    • Grab the deck of the scooter, and pull the wheel downwards.
    • 2 washers will fall out with the wheel.
  5. Hover-1 Rally Brake Pad Replacement, Brake Pad: étape 5, image 1 de 1
    • Begin by removing the two 8.0 mm screws from the deck using the Phillips #2 screwdriver.
    • Two screw caps will come off with the screws
  6. Hover-1 Rally Brake Pad Replacement: étape 6, image 1 de 1
    • Pull the foot brake/ wheel cover away from the deck and downwards.
  7. Hover-1 Rally Brake Pad Replacement: étape 7, image 1 de 1
    • On the foot brake, remove the two 8.0 mm screws using the Phillips #2 screwdriver.
  8. Hover-1 Rally Brake Pad Replacement: étape 8, image 1 de 1
    • On the opposite side of the brake, remove the silver brake pad.
    • If this is your first time replacing this part, the removal might require more force. You may need to use the flat end of a spudger to pry it off.
Elizabeth Picazo
Membre depuis le 02/12/20
189 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team S7-G2, Regan Winter 2020 Membre de l'équipe Cal Poly, Team S7-G2, Regan Winter 2020
CPSU-REGAN-W20S7G2
6 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 2
30 derniers jours : 6
Total : 516
