Aller au contenu principal
Hover-1 Rally Headlight Replacement
Ce dont vous avez besoin
  1. Hover-1 Rally Headlight Replacement, Headlight: étape 1, image 1 de 2 Hover-1 Rally Headlight Replacement, Headlight: étape 1, image 2 de 2
    • Remove four 5 mm screws with a 5 mm hex key.
    • When reinstalling, gently tighten each screw simultaneously to apply equal pressure on both sides of the casing.
  2. Hover-1 Rally Headlight Replacement: étape 2, image 1 de 1
    • Apply pressure to both ends of the headlight to remove it from the scooter.
    • Be gentle. You will feel some resistance due to the glue that is used.
  3. Hover-1 Rally Headlight Replacement: étape 3, image 1 de 1
    • Once the headlight is loose from the scooter, disconnect the two wires using a soldering iron.
    • Use this soldering guide for tips on using a soldering iron.
Cami Lowrey
Membre depuis le 02/07/20
435 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team S7-G2, Regan Winter 2020 Membre de l'équipe Cal Poly, Team S7-G2, Regan Winter 2020
CPSU-REGAN-W20S7G2
6 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 7
30 derniers jours : 21
Total : 430
