Aller au contenu principal
Hover-1 Rally Rear Wheel Replacement
Ce dont vous avez besoin
  1. Hover-1 Rally Rear Wheel Replacement, Rear Wheel: étape 1, image 1 de 1
    • Remove the 4 mm screw in center of the wheel with a 4 mm hex key.
    • Flip the scooter and remove the same size screw from the opposite side of the wheel.
  2. Hover-1 Rally Rear Wheel Replacement: étape 2, image 1 de 1
    • Slide the plastic side piece off from both sides of the scooter.
    • Two 4 mm screws and 2 side panels are taken out.
  3. Hover-1 Rally Rear Wheel Replacement: étape 3, image 1 de 2 Hover-1 Rally Rear Wheel Replacement: étape 3, image 2 de 2
    • Use a 4 mm bit extension to push the axle out of the wheel’s center.
  4. Hover-1 Rally Rear Wheel Replacement: étape 4, image 1 de 1
    • Grab the deck of the scooter, and pull the wheel downwards.
    • 2 washers will fall out with the wheel.
Cami Lowrey
Membre depuis le 02/07/20
435 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team S7-G2, Regan Winter 2020 Membre de l'équipe Cal Poly, Team S7-G2, Regan Winter 2020
CPSU-REGAN-W20S7G2
6 membres
7 tutoriels rédigés
Un commentaire
Where can I buy replacement tires/wheels for the hover-1 rally scooter?
Josh Hatt - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 16
Total : 888
