Aller au contenu principal
Hover-1 Superstar Battery Replacement
Ce dont vous avez besoin
  1. Hover-1 Superstar Battery Replacement, Bottom Case: étape 1, image 1 de 3 Hover-1 Superstar Battery Replacement, Bottom Case: étape 1, image 2 de 3 Hover-1 Superstar Battery Replacement, Bottom Case: étape 1, image 3 de 3
    • Flip your Hover-1 Superstar device upside down.
    • Using a Phillips #1 screwdriver, remove all twenty of the 18mm screws holding the case onto the device.
    • Remove the bottom case. Be careful of the connector holding the case and the device together.
  2. Hover-1 Superstar Battery Replacement: étape 2, image 1 de 1
    • Locate the cable connected to the front lights.
    • Pull apart the wires until the black clip separates.
  3. Hover-1 Superstar Battery Replacement, Battery: étape 3, image 1 de 2 Hover-1 Superstar Battery Replacement, Battery: étape 3, image 2 de 2
    • Locate the four 14mm screws securing the battery bracket.
    • Remove the screws with a Phillips #1 screwdriver.
  4. Hover-1 Superstar Battery Replacement: étape 4, image 1 de 1
    • Pull and disconnect the cable connector that is connected to the battery.
  5. Hover-1 Superstar Battery Replacement: étape 5, image 1 de 1
    • Pull on the battery until it separates from the hover board. You may need to use some force.
    • Be sure the battery is disconnected before performing this step to avoid electrocution.
    • There will be a loud crack when the battery is removed. This is normal due to the adhesive on the back of the battery.
    • Pull the battery out of the hoverboard. Move wires away from the battery if necessary.
Keegan
Membre depuis le 10/04/18
632 Réputation
5 tutoriels rédigés
Un commentaire
How do u get a 25.2v battery at for my hover-1
chivitbprince Boonking - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 7
30 derniers jours : 34
Total : 1,723
