Aller au contenu principal
Hover-1 Titan Left Gyroscope Replacement
Ce dont vous avez besoin
  1. Hover-1 Titan Left Gyroscope Replacement, Bottom Left Panel: étape 1, image 1 de 2 Hover-1 Titan Left Gyroscope Replacement, Bottom Left Panel: étape 1, image 2 de 2
    • Flip the hoverboard so the bottom is facing up.
    • The left side is the side that has the charge port. There is also an "L" on the metal plate underneath the wires.
  2. Hover-1 Titan Left Gyroscope Replacement: étape 2, image 1 de 2 Hover-1 Titan Left Gyroscope Replacement: étape 2, image 2 de 2
    • Using a Phillips #1 screwdriver, remove the two 14 mm screws located closest to the center of the hoverboard.
    • Using a Phillips #1 screwdriver, remove the four 12 mm screws located in the middle of the panel.
    • Using a Phillips #1 screwdriver, remove two 15 mm screws located closest to the wheel.
  3. Hover-1 Titan Left Gyroscope Replacement: étape 3, image 1 de 3 Hover-1 Titan Left Gyroscope Replacement: étape 3, image 2 de 3 Hover-1 Titan Left Gyroscope Replacement: étape 3, image 3 de 3
    • Grip the bottom left panel and lift up to remove.
  4. Hover-1 Titan Left Gyroscope Replacement, Left Gyroscope and Motherboard: étape 4, image 1 de 2 Hover-1 Titan Left Gyroscope Replacement, Left Gyroscope and Motherboard: étape 4, image 2 de 2
    • Unplug the battery from the gyroscope by holding the yellow connector and pulling apart.
  5. Hover-1 Titan Left Gyroscope Replacement: étape 5, image 1 de 3 Hover-1 Titan Left Gyroscope Replacement: étape 5, image 2 de 3 Hover-1 Titan Left Gyroscope Replacement: étape 5, image 3 de 3
    • Remove four 12 mm Phillips #1 head screws from the corners of the green gyroscope/motherboard.
  6. Hover-1 Titan Left Gyroscope Replacement: étape 6, image 1 de 2 Hover-1 Titan Left Gyroscope Replacement: étape 6, image 2 de 2
    • Unplug the bottom right connector by squeezing it and pulling it away from the board.
  7. Hover-1 Titan Left Gyroscope Replacement: étape 7, image 1 de 2 Hover-1 Titan Left Gyroscope Replacement: étape 7, image 2 de 2
    • Unplug the light connector by squeezing it and pulling away from the board.
  8. Hover-1 Titan Left Gyroscope Replacement: étape 8, image 1 de 2 Hover-1 Titan Left Gyroscope Replacement: étape 8, image 2 de 2
    • Unplug the blue and white wires by squeezing the connector and pulling away from the board.
  9. Hover-1 Titan Left Gyroscope Replacement: étape 9, image 1 de 2 Hover-1 Titan Left Gyroscope Replacement: étape 9, image 2 de 2
    • Unplug the small white connector by squeezing it and pulling away from the board.
  10. Hover-1 Titan Left Gyroscope Replacement: étape 10, image 1 de 2 Hover-1 Titan Left Gyroscope Replacement: étape 10, image 2 de 2
    • Unplug the plug in the red connector.
    • The red plug is glued to the board, so this step will require extra force.
  11. Hover-1 Titan Left Gyroscope Replacement: étape 11, image 1 de 2 Hover-1 Titan Left Gyroscope Replacement: étape 11, image 2 de 2
    • Unplug the charging cable connector by squeezing it and pulling it away from the board.
  12. Hover-1 Titan Left Gyroscope Replacement: étape 12, image 1 de 1
    • Cut the cable tie.
    • Unplug the remaining wires.
    • The connectors for the remaining wires are in the rubber covers.
Jessica Ouyang
Membre depuis le 10/08/18
619 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team S15-G4, White Fall 2018 Membre de l'équipe Cal Poly, Team S15-G4, White Fall 2018
CPSU-WHITE-F18S15G4
4 membres
10 tutoriels rédigés
2 commentaires
I’ve got an active broken on the cover not the one to to speaker the other one. Does anyone know where is terminates. I can’t see where it came from. It can only reach the circuit board or the active of the speaker.
Mark - Réponse
Where do you buy the board?
eden11 - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 29
Total : 1,052
