Aller au contenu principal
Hover-1 Titan Right Gyroscope Replacement
Ce dont vous avez besoin
  1. Hover-1 Titan Right Gyroscope Replacement, Bottom Right Panel: étape 1, image 1 de 2 Hover-1 Titan Right Gyroscope Replacement, Bottom Right Panel: étape 1, image 2 de 2
    • Flip the hoverboard so the bottom is facing up.
    • The right side is the side that has the power button. There is also an "R" on the metal plate underneath the battery.
  2. Hover-1 Titan Right Gyroscope Replacement: étape 2, image 1 de 2 Hover-1 Titan Right Gyroscope Replacement: étape 2, image 2 de 2
    • Using a Phillips #1 screwdriver, remove the two 14 mm screws closest to the center of the hoverboard.
    • Using a Phillips #1 screwdriver, remove the four 12 mm screws located in the middle of the panel.
    • Using a Phillips #1 screwdriver, remove the two 15 mm screws located closest to the wheel.
  3. Hover-1 Titan Right Gyroscope Replacement: étape 3, image 1 de 3 Hover-1 Titan Right Gyroscope Replacement: étape 3, image 2 de 3 Hover-1 Titan Right Gyroscope Replacement: étape 3, image 3 de 3
    • Grip the bottom right panel and lift to remove it.
  4. Hover-1 Titan Right Gyroscope Replacement, Right Gyroscope and Motherboard: étape 4, image 1 de 2 Hover-1 Titan Right Gyroscope Replacement, Right Gyroscope and Motherboard: étape 4, image 2 de 2
    • Unplug the battery from the gyroscope/motherboard by holding the yellow connector and pulling apart.
  5. Hover-1 Titan Right Gyroscope Replacement: étape 5, image 1 de 3 Hover-1 Titan Right Gyroscope Replacement: étape 5, image 2 de 3 Hover-1 Titan Right Gyroscope Replacement: étape 5, image 3 de 3
    • Remove four 12 mm Phillips #1 head screws from the corners of the green gyroscope/motherboard.
  6. Hover-1 Titan Right Gyroscope Replacement: étape 6, image 1 de 2 Hover-1 Titan Right Gyroscope Replacement: étape 6, image 2 de 2
    • Unplug the bottom left connector by squeezing it and pulling it away from the board.
  7. Hover-1 Titan Right Gyroscope Replacement: étape 7, image 1 de 2 Hover-1 Titan Right Gyroscope Replacement: étape 7, image 2 de 2
    • Unplug the white wires by squeezing the connector and pulling away from the board.
  8. Hover-1 Titan Right Gyroscope Replacement: étape 8, image 1 de 2 Hover-1 Titan Right Gyroscope Replacement: étape 8, image 2 de 2
    • Unplug one set of the red, white, purple, and black wires by squeezing the connector and pulling away from the board.
  9. Hover-1 Titan Right Gyroscope Replacement: étape 9, image 1 de 2 Hover-1 Titan Right Gyroscope Replacement: étape 9, image 2 de 2
    • Unplug the other set of the red, white, purple, and black wires by squeezing the connector and pulling away from the board.
  10. Hover-1 Titan Right Gyroscope Replacement: étape 10, image 1 de 1
    • Cut the cable tie and unplug the remaining wires.
2 autres ont terminé cette réparation.
Jessica Ouyang
Membre depuis le 10/08/18
619 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team S15-G4, White Fall 2018 Membre de l'équipe Cal Poly, Team S15-G4, White Fall 2018
CPSU-WHITE-F18S15G4
4 membres
10 tutoriels rédigés
Un commentaire
Where can I get the circuit boards for the left and right ?
jfsucher - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 34
Total : 1,086
