Aller au contenu principal
Hover-1 Ultra Charging Port Replacement
Ce dont vous avez besoin
  1. Hover-1 Ultra Charging Port Replacement, Charging Port: étape 1, image 1 de 3 Hover-1 Ultra Charging Port Replacement, Charging Port: étape 1, image 2 de 3 Hover-1 Ultra Charging Port Replacement, Charging Port: étape 1, image 3 de 3
    • Orient the hoverboard so that the pads are facing down.
    • With the Phillips #1 screwdriver, remove all 18 of the screws on the underside of the board.
    • Carefully remove the shell, lifting directly up.
  2. Hover-1 Ultra Charging Port Replacement: étape 2, image 1 de 2 Hover-1 Ultra Charging Port Replacement: étape 2, image 2 de 2
    • Using your hands or a crescent wrench, begin removing the charging port.
    • Turn the charging port counter-clockwise to release it from the shell.
  3. Hover-1 Ultra Charging Port Replacement: étape 3, image 1 de 3 Hover-1 Ultra Charging Port Replacement: étape 3, image 2 de 3 Hover-1 Ultra Charging Port Replacement: étape 3, image 3 de 3
    • Unclip the insulated red and black wires attached to the port from the motherboard
  4. Hover-1 Ultra Charging Port Replacement: étape 4, image 1 de 3 Hover-1 Ultra Charging Port Replacement: étape 4, image 2 de 3 Hover-1 Ultra Charging Port Replacement: étape 4, image 3 de 3
    • Remove the charging port through the assembly.
    • Place new charging port through the assembly.
    • Clip red and black insulated wires into the motherboard.
To reassemble your device, follow the instructions for step 1 in reverse order.
3 autres ont terminé cette réparation.
Camron Clifton
Membre depuis le 10/22/18
409 Réputation
3 tutoriels rédigés
Équipe
UC Davis, Team S7-G5, Lore Fall 2018 Membre de l'équipe UC Davis, Team S7-G5, Lore Fall 2018
UCD-LORE-F18S7G5
3 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 9
Total : 757
