Aller au contenu principal
Hover-1 XLS Front Wheel Replacement
Ce dont vous avez besoin
  1. Hover-1 XLS Front Wheel Replacement, Front Brake: étape 1, image 1 de 3 Hover-1 XLS Front Wheel Replacement, Front Brake: étape 1, image 2 de 3 Hover-1 XLS Front Wheel Replacement, Front Brake: étape 1, image 3 de 3
    • Remove the two, 23 mm Hex #5 screws holding the brake to the bike.
    • Slide the brake mechanism off and turn it upside down to reveal the screw holding the brake wire.
  2. Hover-1 XLS Front Wheel Replacement: étape 2, image 1 de 1
    • Remove the one, 14 mm Hex #4 screw pushing down the brake wire to the brake mechanism on the bottom.
  3. Hover-1 XLS Front Wheel Replacement: étape 3, image 1 de 2 Hover-1 XLS Front Wheel Replacement: étape 3, image 2 de 2
    • Remove the side screw holding the brake wire and mechanism together with your hands.
    • Slide the brake mechanism off from the brake wire.
  4. Hover-1 XLS Front Wheel Replacement, Front Wheel: étape 4, image 1 de 2 Hover-1 XLS Front Wheel Replacement, Front Wheel: étape 4, image 2 de 2
    • Remove the two, 16 mm Hex #4 screws on both of the hub caps in the front wheel.
    • There are two hub caps on the front wheel. Make sure to remove two screws for both hub caps.
  5. Hover-1 XLS Front Wheel Replacement: étape 5, image 1 de 2 Hover-1 XLS Front Wheel Replacement: étape 5, image 2 de 2
    • Using an adjustable spanner wrench, rotate the 165 mm bolt counter-clockwise to remove.
  6. Hover-1 XLS Front Wheel Replacement: étape 6, image 1 de 3 Hover-1 XLS Front Wheel Replacement: étape 6, image 2 de 3 Hover-1 XLS Front Wheel Replacement: étape 6, image 3 de 3
    • After removing the first bolt, the second bolt located on the other side of the wheel will be able to be take off by hand.
    • Pull the wheel and bike in opposite directions to remove the wheel.
2 autres ont terminé cette réparation.
Jonathan Hidalgo
Membre depuis le 01/24/19
596 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team S1-G2, White Winter 2019 Membre de l'équipe Cal Poly, Team S1-G2, White Winter 2019
CPSU-WHITE-W19S1G2
3 membres
6 tutoriels rédigés
Un commentaire
How do I get in touch with customer service for parts?
tried filling out the form on computer and phone as well tablet and it says error.
fox_Jayson@yahoo.com
please reach out
petrasherbin - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 4
30 derniers jours : 24
Total : 1,252
