Aller au contenu principal
How To Clean Nikon Coolpix S30 Lens
Ce dont vous avez besoin
  1. How To Clean Nikon Coolpix S30 Lens, Batteries: étape 1, image 1 de 2 How To Clean Nikon Coolpix S30 Lens, Batteries: étape 1, image 2 de 2
    • Slide the battery cover to the right.
    • The hinge is on the left side of the cover which will allow the cover to stay attached.
  2. How To Clean Nikon Coolpix S30 Lens: étape 2, image 1 de 2 How To Clean Nikon Coolpix S30 Lens: étape 2, image 2 de 2
    • Slide the second cover (yellow) to the right (similar to the outer cover). This will allow the batteries to be exposed.
  3. How To Clean Nikon Coolpix S30 Lens: étape 3, image 1 de 1
    • Remove the batteries by gently tipping the camera.
  4. How To Clean Nikon Coolpix S30 Lens, How To Clean Nikon Coolpix S30 Lens: étape 4, image 1 de 1
    • Remove the four screws the hold the back of the case to the rest of the camera.
  5. How To Clean Nikon Coolpix S30 Lens: étape 5, image 1 de 1
    • Remove the left screw from the bottom of the camera first. This can be done using the same T5 tip.
    • Unscrew the screw on the right using a different attachment: PH000 (it is a small Phillip's head)
  6. How To Clean Nikon Coolpix S30 Lens: étape 6, image 1 de 1
    • Remove back case from the rest of the camera carefully.
  7. How To Clean Nikon Coolpix S30 Lens: étape 7, image 1 de 1
    • Remove the three screws the secure the motherboard to the front case.
  8. How To Clean Nikon Coolpix S30 Lens: étape 8, image 1 de 2 How To Clean Nikon Coolpix S30 Lens: étape 8, image 2 de 2
    • Remove the motherboard from the front case.
    • Leave the red and black wire attached but lay the piece in front of the case.
  9. How To Clean Nikon Coolpix S30 Lens: étape 9, image 1 de 2 How To Clean Nikon Coolpix S30 Lens: étape 9, image 2 de 2
    • Wipe the lens and the clear plastic on the front case to remove debris.
Courtney Weida
Membre depuis le 01/21/15
167 Réputation
1 tutoriel rédigé
Équipe
Penn State, Team 2-4, Kaschak Winter 2015 Membre de l'équipe Penn State, Team 2-4, Kaschak Winter 2015
PSU-KASCHAK-W15S2G4
4 membres
5 tutoriels rédigés
Un commentaire
The first three steps are redundant because you already included the prerequisite guide for removal of the batteries.
Dylan Keiter - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 5
Total : 1,651
