Aller au contenu principal
How To Fix A Hole In Khaki Pants
Ce dont vous avez besoin
  1. How To Fix A Hole In Khaki Pants, How To Fix A Hole In Khaki Pants: étape 1, image 1 de 1
    • Examine the damaged area.
    • Make sure to clean all the debris from the tear.
  2. How To Fix A Hole In Khaki Pants: étape 2, image 1 de 1
    • Flip your pants inside out.
  3. How To Fix A Hole In Khaki Pants: étape 3, image 1 de 1
    • Pinch hole together.
    • Make sure there is no gaps showing.
  4. How To Fix A Hole In Khaki Pants: étape 4, image 1 de 1
    • Pin needle and thread through pants.
    • Use more thread than needed so you will have enough.
    • Make sure your hand is not directly behind the needle where you are poking. This will prevent you from pricking yourself.
  5. How To Fix A Hole In Khaki Pants: étape 5, image 1 de 2 How To Fix A Hole In Khaki Pants: étape 5, image 2 de 2
    • Pull needle and thread through pants until there is only 2 inches of thread left.
    • Tie a knot at the end of the remaining 2 inches.
    • It can be any measurement, but 2 inches makes it easier to tie a knot without wasting too much thread.
  6. How To Fix A Hole In Khaki Pants: étape 6, image 1 de 2 How To Fix A Hole In Khaki Pants: étape 6, image 2 de 2
    • Take the needle and pin it through right next to the previous spot.
    • Pull all the way through until thread is tight.
    • Repeat this process until you reach the end of the hole.
  7. How To Fix A Hole In Khaki Pants: étape 7, image 1 de 1
    • Wrap the thread three times around the needle.
    • Pull the needle until the thread is tight.
    • This will tie a knot at the end.
  8. How To Fix A Hole In Khaki Pants: étape 8, image 1 de 1
    • Take the scissors and cut the excess string remaining.
  9. How To Fix A Hole In Khaki Pants: étape 9, image 1 de 1
    • Now put your khaki pants on because they are now wearable again and practically new!
Now your old ripped pants look practically new and you can begin wearing them again.
6 autres ont terminé cette réparation.
Calvin Roth
Membre depuis le 09/27/15
291 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 17-1, Green Fall 2015 Membre de l'équipe Cal Poly, Team 17-1, Green Fall 2015
CPSU-GREEN-F15S17G1
4 membres
5 tutoriels rédigés
5 commentaires
it's 100% not ok...... i con do it so 99% ok
Shafikahmed - Réponse
and 100% maching
Iam shafik i can't do it's and 100% maching
What about if you’re in school and your pants rip?
EMMA MILLER - Réponse
is it smooth when you fix it? i use these for school and dont want it to show
JORDI ZAMUDIO - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 8
7 derniers jours : 32
30 derniers jours : 164
Total : 51,373
