Aller au contenu principal
How To Fix a Jammed Box Cutter
Ce dont vous avez besoin
  1. How To Fix a Jammed Box Cutter, How To Fix a Jammed Box Cutter: étape 1, image 1 de 3 How To Fix a Jammed Box Cutter, How To Fix a Jammed Box Cutter: étape 1, image 2 de 3 How To Fix a Jammed Box Cutter, How To Fix a Jammed Box Cutter: étape 1, image 3 de 3
    • Using a Phillips head screwdriver, unscrew the screw on the box cutter.
    • Remove the top part of the box cutter.
  2. How To Fix a Jammed Box Cutter: étape 2, image 1 de 3 How To Fix a Jammed Box Cutter: étape 2, image 2 de 3 How To Fix a Jammed Box Cutter: étape 2, image 3 de 3
    • Caution: Sharp Object Involved
    • Pick up the blade.
    • Separate the blade from the trigger.
  3. How To Fix a Jammed Box Cutter: étape 3, image 1 de 3 How To Fix a Jammed Box Cutter: étape 3, image 2 de 3 How To Fix a Jammed Box Cutter: étape 3, image 3 de 3
    • Look for the sliding bar and circle which will be located towards the end of the box cutter.
    • Place the trigger aligning with the sliding bar and the circle in the middle of the box cutter.
    • Apply pressure with your finger onto the magnetic part of the trigger to secure placement.
  4. How To Fix a Jammed Box Cutter: étape 4, image 1 de 2 How To Fix a Jammed Box Cutter: étape 4, image 2 de 2
    • Carefully pick up the blade and identify the left hook of the blade and identify the hook of the trigger.
    • Align the hook from the blade on top of the trigger hook.
  5. How To Fix a Jammed Box Cutter: étape 5, image 1 de 2 How To Fix a Jammed Box Cutter: étape 5, image 2 de 2
    • Place the box cutter back together.
  6. How To Fix a Jammed Box Cutter: étape 6, image 1 de 2 How To Fix a Jammed Box Cutter: étape 6, image 2 de 2
    • Hand tightly screw the screw back into the box cutter.
    • Finish off screwing the screw into the box cutter with the screw driver.
Yailene
Membre depuis le 10/23/23
133 Réputation
1 tutoriel rédigé
Équipe
Sam Houston State, Team 1-2, Bennett Fall 2023 Membre de l'équipe Sam Houston State, Team 1-2, Bennett Fall 2023
SHSU-BENNETT-F23S1G2
2 membres
1 tutoriel rédigé
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 31
30 derniers jours : 158
Total : 2,296
