Aller au contenu principal
How To Fix a Torn Book Page
Ce dont vous avez besoin
  1. How To Fix a Torn Book Page, How To Fix a Torn Book Page: étape 1, image 1 de 1
    • Lay out all of the equipment needed for the repair.
  2. How To Fix a Torn Book Page: étape 2, image 1 de 1
    • Place one piece of wax paper behind the torn page.
    • The wax paper is used to protect the other pages from the glue.
  3. How To Fix a Torn Book Page: étape 3, image 1 de 1
    • Be very careful in aligning the torn piece with the page, as realignment after gluing will be difficult.
    • Make sure to align the torn pieces precisely. Placing them too closely or too far apart may create an issue in reading the pages later.
    • Align the torn pieces, so they connect the images/text accurately and neatly.
    • You may use a clamp to hold the torn pieces together to make gluing easier.
  4. How To Fix a Torn Book Page: étape 4, image 1 de 3 How To Fix a Torn Book Page: étape 4, image 2 de 3 How To Fix a Torn Book Page: étape 4, image 3 de 3
    • Do not apply too much glue, only enough to evenly cover the tear between the page and the torn piece.
    • Remove any excess glue to prevent the pages from sticking to the wax paper.
    • Grab the fabric glue and squeeze a line of glue all the way along the crevice (tear).
    • Use a small paintbrush to apply a moderate amount of glue along the edges of the ripped areas.
  5. How To Fix a Torn Book Page: étape 5, image 1 de 1
    • Place the second sheet of wax paper on top of the page you just glued.
    • Be careful when placing the wax paper on top of the wet glue. Moving the wax paper around will make the glue smear.
  6. How To Fix a Torn Book Page: étape 6, image 1 de 1
    • Wrap the closed book with several rubber bands to squeeze and compress during drying time.
  7. How To Fix a Torn Book Page: étape 7, image 1 de 2 How To Fix a Torn Book Page: étape 7, image 2 de 2
    • You can also use several books or other heavy items to add extra weight.
  8. How To Fix a Torn Book Page: étape 8, image 1 de 2 How To Fix a Torn Book Page: étape 8, image 2 de 2
    • Let the glue dry for 6 hours minimum to ensure that it dries completely.
    • Carefully peel the top sheet of wax paper first, and then remove the bottom one afterwards.
Ligne d'arrivée
3 autres ont terminé cette réparation.
Un commentaire
Thanks for article!
Alex White - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 10
7 derniers jours : 79
30 derniers jours : 386
Total : 8,815
