Aller au contenu principal
How To Open A Desktop Hard Drive
Ce dont vous avez besoin
  1. How To Open A Desktop Hard Drive, Remove The Front Screws: étape 1, image 1 de 2 How To Open A Desktop Hard Drive, Remove The Front Screws: étape 1, image 2 de 2
    • Use a size 8 Torx screwdriver to remove the front screws. The location and amount may vary depending on your drive, but they are very easy to locate.
  2. How To Open A Desktop Hard Drive, Removing The Hidden Screws: étape 2, image 1 de 2 How To Open A Desktop Hard Drive, Removing The Hidden Screws: étape 2, image 2 de 2
    • There may be a screw hidden under the front sticker, so make sure to peel it off and check before you open it up. Use a spudger to peel off any material in the way of the screw
    • Please check under the sticker before you open up your disk drive. I didn't, and went full brute-force on the hard drive cover. Whoops!
  3. How To Open A Desktop Hard Drive: étape 3, image 1 de 2 How To Open A Desktop Hard Drive: étape 3, image 2 de 2
    • Slide a spudger around the front cover to remove any adhesive or rubber insulation before opening.
  4. How To Open A Desktop Hard Drive: étape 4, image 1 de 1
    • Gently remove the cover.
    • Do NOT do what I did, please.
  5. How To Open A Desktop Hard Drive: étape 5, image 1 de 1
    • There you have it! Now you have a fully-opened hard drive. Whether you want to make a pretty cool (and large) paperweight or perma-delete your data, you can now do so.
This is not a reversible process. I am not responsible for any damage done to you or your hard drive while opening it.
10 autres ont terminé cette réparation.
gamer_Kat
Membre depuis le 11/11/23
391 Réputation
1 tutoriel rédigé
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 13
30 derniers jours : 80
Total : 1,574
