Aller au contenu principal
How To Patch a Hole in Umbrella Fabric
Ce dont vous avez besoin
  1. How To Patch a Hole in Umbrella Fabric, Fabric: étape 1, image 1 de 1
    • Remove the fabric from the extender arms of your umbrella.
    • This allows you to more easily work with the torn area, as the fabric won't be held tightly.
  2. How To Patch a Hole in Umbrella Fabric: étape 2, image 1 de 1
    • Sew the tear together from the back side of the umbrella using your needle and nylon thread.
    • Be sure to use a thin gauge nylon thread, as cotton threads will soak through and cause leaks in your canopy.
  3. How To Patch a Hole in Umbrella Fabric: étape 3, image 1 de 1
    • Cut your patch to an appropriate size relative to the tear.
    • The size of your patch should be big enough to completely cover the tear, with around an inch of additional material on all sides.
  4. How To Patch a Hole in Umbrella Fabric: étape 4, image 1 de 1
    • Apply your fabric glue to the backside of your patch material.
  5. How To Patch a Hole in Umbrella Fabric: étape 5, image 1 de 1
    • Lay the torn area of the fabric on a flat surface.
  6. How To Patch a Hole in Umbrella Fabric: étape 6, image 1 de 1
    • Apply your patch squarely over the torn fabric.
To reassemble your umbrella, reattach the fabric to the rivets that you disconnected it from.
Brandon Hillert
Membre depuis le 10/04/20
133 Réputation
1 tutoriel rédigé
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 24
7 derniers jours : 180
30 derniers jours : 761
Total : 13,922
