Aller au contenu principal
Pour réparer ensemble - Je crée un compte
How To Properly Use And Maintain Your Juicer
Ce dont vous avez besoin
    • Examine whether you use a traditional centrifugal juicer or a slow auger juicer to understand performance and noise levels.
    • Recognize that smaller centrifugal models have a narrow feed chute and might require more chopping.
    • Notice that larger centrifugal models have a bigger feed chute, letting you use larger produce pieces.
    • Slow or auger juicers compress produce at lower speeds and can handle leafy greens more effectively.
    Demander à FixBot
    Ajouter un commentaire
    • Unplug the juicer from the power source before handling the internal parts or performing any maintenance.
    • Clean and cut fresh produce to fit into the feed chute, especially for smaller centrifugal machines.
    • Apply gentle pressure when inserting hard ingredients such as beetroot to avoid straining the motor.
    Demander à FixBot
    • Plug in the machine only when ready to juice and ensure the lid is securely attached.
    • For slow juicers, use the reverse function if ingredients become jammed to release stuck pieces.
    Demander à FixBot
    • Place a small bag inside the pulp container to make cleanup easier and allow reuse of pulp if desired.
    Demander à FixBot
    • Use the slow juicer to puree tomatoes or softer fruits, collecting juice and pulp separately.
    Demander à FixBot
    • Clean the juicer parts immediately after use to prevent build-up and reduce scrubbing time.
    • Discard or reuse all pulp, taking care to empty the container before washing.
    • Avoid using a dishwasher for the filter or mesh to prevent damage or warping.
    • Use a soft brush under running water to remove residue from both the fine mesh and removable parts.
    • Apply the same cleaning rules for slow juicers, including rinsing the auger and strainer right away.
    Demander à FixBot
    • Check the device manual to avoid any action that could void your warranty or risk damage.
    • Store all parts in a dry place and handle them carefully to prolong the motor and component lifespan.
    Demander à FixBot
A juicer can deliver fresh, nutritious beverages if met with proper use and care. Clean right after juicing and respect the device’s specific guidelines for a smooth experience and longer service life. Always remember to unplug your juicer before any maintenance to stay safe and maintain your warranty.
Ula Gantar
Membre depuis le 01/08/25
16 609 Réputation
81 tutoriels rédigés
Équipe
ZEOS Slovenia Membre de l'équipe ZEOS Slovenia
Local Repair Groups
2 membres
165 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 30
Total : 212
