Aller au contenu principal
How To Re-String A Hoodie
Tutoriel Archivé
Ce tutoriel est conservé uniquement à des fins de suivis historiques. Utilisez la version actuelle du tutoriel pour effectuer votre réparation.
Ce dont vous avez besoin
  1. How To Re-String A Hoodie, How To Re-String A Hoodie: étape 1, image 1 de 2 How To Re-String A Hoodie, How To Re-String A Hoodie: étape 1, image 2 de 2
    • Uncoil the wire coat hanger into a straight line.
  2. How To Re-String A Hoodie: étape 2, image 1 de 3 How To Re-String A Hoodie: étape 2, image 2 de 3 How To Re-String A Hoodie: étape 2, image 3 de 3
    • Tape the end of the uncoiled coat hanger to one end of your sweatshirt string.
    • Make sure the clothes hanger is securely taped to ensure that the string doesn't detach during the re-stringing process.
    • When taping, make sure no adhesive is felt over the outside of the apparatus. This will make the re-stringing process easier because the tape won't be sticking to the sweatshirt.
  3. How To Re-String A Hoodie: étape 3, image 1 de 1
    • Insert the wire and string apparatus into the left opening of the hoodie.
  4. How To Re-String A Hoodie: étape 4, image 1 de 1
    • Feed the wire through the hoodie until it reaches the top of the hood.
  5. How To Re-String A Hoodie: étape 5, image 1 de 2 How To Re-String A Hoodie: étape 5, image 2 de 2
    • Curve the wire to the right so that the wire can follow the curve of the hood.
  6. How To Re-String A Hoodie: étape 6, image 1 de 2 How To Re-String A Hoodie: étape 6, image 2 de 2
    • Continue feeding the wire through the hood towards the other opening of the hoodie.
    • Pull the wire and string out of the opening.
  7. How To Re-String A Hoodie: étape 7, image 1 de 2 How To Re-String A Hoodie: étape 7, image 2 de 2
    • Remove the tape from the end of the wire and string.
  8. How To Re-String A Hoodie: étape 8, image 1 de 2 How To Re-String A Hoodie: étape 8, image 2 de 2
    • Remove the wire from the hoodie by pushing the left end of the wire through the hoodie, while pulling the right end out.
  9. How To Re-String A Hoodie: étape 9, image 1 de 1
    • Tie each end of the string in a knot to prevent the string from coming out of the hoodie.
Congratulations on restringing your hoodie!
4 autres ont terminé cette réparation.
Ashley
Membre depuis le 02/24/15
267 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 23-1, Green Winter 2015 Membre de l'équipe Cal Poly, Team 23-1, Green Winter 2015
CPSU-GREEN-W15S23G1
4 membres
4 tutoriels rédigés
Un commentaire
my apple iphone 4 is disabled connect to itunes
Ali Hemmati - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 272
