Introduction
Passez à l'étape 1 ↓This guide will walk you through removing, cleaning, lubricating, and reassembling an older model coaster brake.
Ce dont vous avez besoin
Pièces
Tube of Marine Bearing Grease
Type isn't critical, but this is cheap and easy to find. I actually used White Lithium Grease.
Outils
×2Adjustable Wrench$28.954.8
Fixed Wrenches can also be used, but several sizes will be needed, and they will be metric
×2
×2Rags
Dry and Clean
Plastic Tub
This is to wash the parts. Put about two inches of water in it.
Loosen the nuts holding the axle in place using the two wrenches.
Unscrew the brake arm from the frame of the bicycle using the screwdriver.
Reassemble the parts of the bearing and axle assembly which go on the opposite side of the hub from the sprocket. This includes the brake pads and the cone
Using your fingers, make sure the bearings are well coated with grease.
Make sure to add some grease at key points shown (red lines).
Congratulations! You've finished cleaning your coaster brake. Test-ride the bicycle. Listen to make sure that there are no grinding noises. Be sure to test the brake several times. When you're done, make sure all the nuts are still tight.
7 autres ont terminé cette réparation.
3 commentaires de tutoriel
I have Huffy coaster bike 26”, i’m trying to change the rear tire bearing but I don’t know the size of it. the outside ones are 3/16 X9, but I need to know the size of the small inner one at the gear it was 7 balls.
Can you explicitly say which order the parts go back in?
It should be easy, but I can't quite get it straight.
Okay let’s say I’m an idiot and I got parts everywhere trying to do this and deal with twin toddlers and a 9 year old daughter going on 25 is there a set of instructions that says the name of the part is connected to the name of the part connected to the name of the part etc…
