Aller au contenu principal
Pour réparer ensemble - Je crée un compte
How To Repair A Sticking Mountain Bike Brake Line
Ce dont vous avez besoin
  1. How To Repair A Sticking Mountain Bike Brake Line, How To Repair A Sticking Mountain Bike Brake Line: étape 1, image 1 de 3 How To Repair A Sticking Mountain Bike Brake Line, How To Repair A Sticking Mountain Bike Brake Line: étape 1, image 2 de 3 How To Repair A Sticking Mountain Bike Brake Line, How To Repair A Sticking Mountain Bike Brake Line: étape 1, image 3 de 3
    • Remove the grip from the bike's handle bar.
    • Use short twisting motions. If the grip is really stuck onto the bar, some soapy water can help it come off easier.
    Demander à FixBot
    Ajouter un commentaire
  2. How To Repair A Sticking Mountain Bike Brake Line: étape 2, image 1 de 2 How To Repair A Sticking Mountain Bike Brake Line: étape 2, image 2 de 2
    • Unscrew the hex screw on the brake fixture on the handle bars with the allen wrench.
    • Once the brake fixture is loose, pull off the fixture form the handle and set aside.
    Demander à FixBot
  3. How To Repair A Sticking Mountain Bike Brake Line: étape 3, image 1 de 3 How To Repair A Sticking Mountain Bike Brake Line: étape 3, image 2 de 3 How To Repair A Sticking Mountain Bike Brake Line: étape 3, image 3 de 3
    • Unhook the brake line from the bike's body by sliding the line backwards and pulling up in one motion.
    • If the brake line is too tight to pull back, you may have to remove the rear tire to let the brake pads move farther.
    Demander à FixBot
  4. How To Repair A Sticking Mountain Bike Brake Line: étape 4, image 1 de 3 How To Repair A Sticking Mountain Bike Brake Line: étape 4, image 2 de 3 How To Repair A Sticking Mountain Bike Brake Line: étape 4, image 3 de 3
    • Remove the brake line from the brake assembly you removed in step one.
    • Unscrew the adjustment screw all the way out of the assembly.
    • Push brake line forward and slide the line out of the slot in the brake handle.
    • Check the spring of the brake lever without the line connected. If it does not retract well, you can clean it with soapy water.
    Demander à FixBot
  5. How To Repair A Sticking Mountain Bike Brake Line: étape 5, image 1 de 2 How To Repair A Sticking Mountain Bike Brake Line: étape 5, image 2 de 2
    • To remove the brake line from the rear brake pads. Unhook the line from the metal insert.
    • Unscrew the hex bolt with an allen wrench.
    Demander à FixBot
  6. How To Repair A Sticking Mountain Bike Brake Line: étape 6, image 1 de 1
    • After you have removed the bike's brake line, take the whole assembly wipe with a soapy water solution to remove rust, dirt, grease and anything else stopping the line from traveling freely.
    • After removing all of the debris, apply chain oil to another rag and wipe oil evenly onto the line.
    • Careful the line itself could be frayed anywhere due to age and be sharp.
    Demander à FixBot
Once finished, put back together the brake assembly. Then test the mobility of the brakes before riding. Happy Riding!
4 autres ont terminé cette réparation.
Spencer Solano
Membre depuis le 04/09/15
342 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 30-1, Green Spring 2015 Membre de l'équipe Cal Poly, Team 30-1, Green Spring 2015
CPSU-GREEN-S15S30G1
4 membres
14 tutoriels rédigés
1 commentaire de tutoriel
I’d like to comment just because I think it’s unnecessary to remove the brake leaver as it can be quite a troublesome job to remove and refit the grip and there is really no need to do so in this instance.
ndlz84 - Réponse Partager
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 9
30 derniers jours : 35
Total : 8,225
