Aller au contenu principal
How To Repair An Overheating D-LINK DIR-655 Wireless Router
Ce dont vous avez besoin
  1. How To Repair An Overheating D-LINK DIR-655 Wireless Router, How To Repair An Overheating D-LINK DIR-655 Wireless Router: étape 1, image 1 de 2 How To Repair An Overheating D-LINK DIR-655 Wireless Router, How To Repair An Overheating D-LINK DIR-655 Wireless Router: étape 1, image 2 de 2
    • Start by removing the three antennas by twisting each one in a counter-clockwise direction when facing the back panel.
  2. How To Repair An Overheating D-LINK DIR-655 Wireless Router: étape 2, image 1 de 2 How To Repair An Overheating D-LINK DIR-655 Wireless Router: étape 2, image 2 de 2
    • Using your flathead screwdriver or plastic opening tool, gently pry the top two screw covers out of the router's case.
  3. How To Repair An Overheating D-LINK DIR-655 Wireless Router: étape 3, image 1 de 3 How To Repair An Overheating D-LINK DIR-655 Wireless Router: étape 3, image 2 de 3 How To Repair An Overheating D-LINK DIR-655 Wireless Router: étape 3, image 3 de 3
    • Using your Phillips screwdriver, turn the screw counter-clockwise to remove it from the assembly.
    • Do the same for the second screw.
  4. How To Repair An Overheating D-LINK DIR-655 Wireless Router: étape 4, image 1 de 1
    • Gently pry the top of the case from the sides and bottom of the router.
    • After freeing the top, remove it and set it aside.
  5. How To Repair An Overheating D-LINK DIR-655 Wireless Router: étape 5, image 1 de 2 How To Repair An Overheating D-LINK DIR-655 Wireless Router: étape 5, image 2 de 2
    • With your Phillips screwdriver, remove both screws by rotating in a counter-clockwise direction.
  6. How To Repair An Overheating D-LINK DIR-655 Wireless Router: étape 6, image 1 de 1
    • After removing the screws, lift the white LED cover up and off of the circuit board.
  7. How To Repair An Overheating D-LINK DIR-655 Wireless Router: étape 7, image 1 de 3 How To Repair An Overheating D-LINK DIR-655 Wireless Router: étape 7, image 2 de 3 How To Repair An Overheating D-LINK DIR-655 Wireless Router: étape 7, image 3 de 3
    • Next, bend up the clip holding down the middle antenna wire.
    • Gently, unhook the wire and move it out of the way.
  8. How To Repair An Overheating D-LINK DIR-655 Wireless Router: étape 8, image 1 de 1
    • With the wire out of the way, separate the circuit board from the bottom assembly.
    • Be sure not to pinch or bend the antenna wire when you lift the circuit board.
  9. How To Repair An Overheating D-LINK DIR-655 Wireless Router: étape 9, image 1 de 1
    • Wipe away any dust from the the vents to ensure proper airflow.
6 autres ont terminé cette réparation.
Chance Daniel
Membre depuis le 09/29/15
263 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 10-6, Green Fall 2015 Membre de l'équipe Cal Poly, Team 10-6, Green Fall 2015
CPSU-GREEN-F15S10G6
3 membres
3 tutoriels rédigés
Un commentaire
Fixed my unit :-)
larry_wollen - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 31
Total : 5,499
