Aller au contenu principal
How To Repair a Faulty Switch on a Trio-60 Keyboard
Ce dont vous avez besoin
  1. How To Repair a Faulty Switch on a  Trio-60 Keyboard, Key Switch: étape 1, image 1 de 2 How To Repair a Faulty Switch on a  Trio-60 Keyboard, Key Switch: étape 1, image 2 de 2
    • Unplug the keyboard
  2. How To Repair a Faulty Switch on a  Trio-60 Keyboard: étape 2, image 1 de 3 How To Repair a Faulty Switch on a  Trio-60 Keyboard: étape 2, image 2 de 3 How To Repair a Faulty Switch on a  Trio-60 Keyboard: étape 2, image 3 de 3
    • Use a keycap puller to remove the keycaps "3", "4", "0'", "-", "Caps Lock", "enter" and both "alt" keys to gain access to screws.
    • Place the keycap puller straight over the keycap, so that the wires are under the keycap and pull straight up.
    • It may require slight angling and pressure to remove the keycap.
  3. How To Repair a Faulty Switch on a  Trio-60 Keyboard: étape 3, image 1 de 3 How To Repair a Faulty Switch on a  Trio-60 Keyboard: étape 3, image 2 de 3 How To Repair a Faulty Switch on a  Trio-60 Keyboard: étape 3, image 3 de 3
    • Remove six 4.0 mm screws with a Phillips #0 screwdriver.
    • Consider using a magnetized screwdriver or magnet to remove screws, or leave them in the chassis.
  4. How To Repair a Faulty Switch on a  Trio-60 Keyboard: étape 4, image 1 de 2 How To Repair a Faulty Switch on a  Trio-60 Keyboard: étape 4, image 2 de 2
    • Remove the top chassis (metal cover) by lifting straight up and off of the keyboard.
  5. How To Repair a Faulty Switch on a  Trio-60 Keyboard: étape 5, image 1 de 3 How To Repair a Faulty Switch on a  Trio-60 Keyboard: étape 5, image 2 de 3 How To Repair a Faulty Switch on a  Trio-60 Keyboard: étape 5, image 3 de 3
    • Gently flip the plate and PCB towards the back of the case, so that it lies upside down behind the case.
    • Ensure not to pull on or twist the keyboard as it's attached to a cable and could cause damage.
  6. How To Repair a Faulty Switch on a  Trio-60 Keyboard: étape 6, image 1 de 2 How To Repair a Faulty Switch on a  Trio-60 Keyboard: étape 6, image 2 de 2
    • Use your fingers or a spudger to remove the JST cable on the end of the circuit board.
  7. How To Repair a Faulty Switch on a  Trio-60 Keyboard: étape 7, image 1 de 2 How To Repair a Faulty Switch on a  Trio-60 Keyboard: étape 7, image 2 de 2
    • Make sure to desolder in a well-ventilated area, as the smoke released from the boiling flux is toxic. Placing a small fan near and facing away from your soldering area is recommended.
    • Heat the solder until it appears liquified.
    • Use your preferred sucking tool of choice to remove the solder (an electric desolder is recommended).
    • Desolder both points for each switch you are removing.
    • The location of desoldering may vary depending on which switches are faulty.
  8. How To Repair a Faulty Switch on a  Trio-60 Keyboard: étape 8, image 1 de 2 How To Repair a Faulty Switch on a  Trio-60 Keyboard: étape 8, image 2 de 2
    • Use a switch puller or your fingers to remove the faulty switch.
  9. How To Repair a Faulty Switch on a  Trio-60 Keyboard: étape 9, image 1 de 3 How To Repair a Faulty Switch on a  Trio-60 Keyboard: étape 9, image 2 de 3 How To Repair a Faulty Switch on a  Trio-60 Keyboard: étape 9, image 3 de 3
    • If a pin is bent, flatten it with pliers so that it is perpendicular to the switch.
    • If the pin is not bent, there may be electronic issues causing switch malfunction that will not be covered in this guide.
  10. How To Repair a Faulty Switch on a  Trio-60 Keyboard: étape 10, image 1 de 2 How To Repair a Faulty Switch on a  Trio-60 Keyboard: étape 10, image 2 de 2
    • Place the new or repaired switch straight down until it is firmly locked into plate.
  11. How To Repair a Faulty Switch on a  Trio-60 Keyboard: étape 11, image 1 de 1
    • Solder the switch and test the keyboard to ensure it functions correctly.
    • Make sure to solder in a well-ventilated area, as the smoke released from the boiling flux is toxic. Placing a small fan near and facing away from your soldering area is recommended.
  12. How To Repair a Faulty Switch on a  Trio-60 Keyboard: étape 12, image 1 de 2 How To Repair a Faulty Switch on a  Trio-60 Keyboard: étape 12, image 2 de 2
    • Optionally apply isopropyl alcohol to Q-tip and clean flux residue from solder joints.
Chase Keighley
Membre depuis le 04/19/23
205 Réputation
1 tutoriel rédigé
Équipe
UC Davis, Team 1-3, Morris Spring 2023 Membre de l'équipe UC Davis, Team 1-3, Morris Spring 2023
UCD-MORRIS-S23S1G3
3 membres
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 24
Total : 241
