Aller au contenu principal
Pour réparer ensemble - Je crée un compte
How To Replace The Clutch In Your Blender
Ce dont vous avez besoin
    • Ensure the blender is powered off and remove the plug from the wall outlet.
    Demander à FixBot
    Ajouter un commentaire
    • Detach any removable container or lid from the top of the blender and set it aside.
    • Flip the motor base to access the screws securing the housing.
    • Use a Torx driver to remove the screws and gently lift the housing off the motor unit.
    Demander à FixBot
    • Locate the notch on the rotor and insert a flathead screwdriver to block the shaft from turning.
    • Grip the old clutch and rotate it counterclockwise to loosen and remove it from the rotor.
    • Apply a small amount of lubricant if the clutch is stuck or difficult to remove.
    • Check if your blender uses a slip-on type that pulls off rather than unscrews.
    Demander à FixBot
    • Apply a small amount of machine oil to the bushings around the rotor shaft.
    • Wipe away any excess oil to prevent drips inside the housing.
    Demander à FixBot
    • Thread or press the new clutch onto the rotor shaft in the correct orientation.
    • Block the rotor with a screwdriver and hand-tighten the clutch to secure it.
    • Do not overtighten because it will self-tighten during blending.
    Demander à FixBot
    • Align the housing with the motor base and lower it into place.
    • Secure the housing with the Torx screws and verify it sits flush.
    • Use reference photos if needed to confirm all parts are positioned correctly.
    • Plug in the blender briefly to verify that the new clutch engages properly.
    Demander à FixBot
    • Inspect for unusual noises or wobbling during operation and power off immediately if problems occur.
    • Clean the blender housing regularly to prevent debris from causing clutch wear.
    Demander à FixBot
Regularly inspect the clutch for wear or damage, especially if you blend heavy ingredients often. Lubricating the bushings and securing the blender housing will help maintain optimal performance. A properly installed and well-maintained clutch ensures your blender serves you reliably for many more mixes and blends.
Ula Gantar
Membre depuis le 01/08/25
16 609 Réputation
81 tutoriels rédigés
Équipe
ZEOS Slovenia Membre de l'équipe ZEOS Slovenia
Local Repair Groups
2 membres
95 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 13
30 derniers jours : 39
Total : 435
