Aller au contenu principal
How To Restring a Left Handed Guitar
  1. How To Restring a Left Handed Guitar, Guitar Strings: étape 1, image 1 de 3 How To Restring a Left Handed Guitar, Guitar Strings: étape 1, image 2 de 3 How To Restring a Left Handed Guitar, Guitar Strings: étape 1, image 3 de 3
    • For each string, turn its tuning nob so that the string is slack, then uncoil it from the tuning peg.
  2. How To Restring a Left Handed Guitar: étape 2, image 1 de 3 How To Restring a Left Handed Guitar: étape 2, image 2 de 3 How To Restring a Left Handed Guitar: étape 2, image 3 de 3
    • Untie the loops connecting the three thinner strings to the bridge and remove the strings.
    • Apply force away from the neck on the three thicker strings to unseat them from the bridge, then remove the strings.
    • Once each string is out, coil it up.
    • Make sure to be careful of the sharp edges on the strings.
    • For restringing a guitar, it is helpful to label the strings in some way such as placing each string on a labeled note card.
  3. How To Restring a Left Handed Guitar: étape 3, image 1 de 3 How To Restring a Left Handed Guitar: étape 3, image 2 de 3 How To Restring a Left Handed Guitar: étape 3, image 3 de 3
    • To restring the guitar for a left-handed guitar player, flip the guitar so that the strings can be put on in reverse. The guitar's neck should face to the right when the guitar is sitting on your lap.
    • Pull each string through the bridge.
    • Retie each of the three thinner strings to the bridge.
    • Push each of the three thicker strings through the bottom of the bridge, locking it in place.
    • It is essential to make sure the strings are in the right order when restringing a guitar. The thickest string, the low E, should be highest from the ground when playing the guitar. The order goes: low E on the top, followed by A, D, G, B, and then high E, the thinnest string, on the bottom.
  4. How To Restring a Left Handed Guitar: étape 4, image 1 de 3 How To Restring a Left Handed Guitar: étape 4, image 2 de 3 How To Restring a Left Handed Guitar: étape 4, image 3 de 3
    • Feed each string through the guitar and into its respective tuning peg, then tighten the tuning peg.
  5. How To Restring a Left Handed Guitar: étape 5, image 1 de 3 How To Restring a Left Handed Guitar: étape 5, image 2 de 3 How To Restring a Left Handed Guitar: étape 5, image 3 de 3
    • Tune the guitar, using either your ears or an electric tuner.
    • If you want to improve the sound quality of the left-handed strung guitar, the guitar's nut can be replaced with a left-handed guitar nut for better sound quality.
    • If the guitar uses a saddle, the saddle and its slots can be adjusted to help the strings fit better. One could also buy and install a new left-handed bridge for the same effect.
Enjoy your left-handed strung guitar!
Happy fixing!
Joseph Chavez
Membre depuis le 08/22/22
121 Réputation
1 tutoriel rédigé
Équipe
CSU Los Angeles, Team 3-10, Briggs Fall 2022 Membre de l'équipe CSU Los Angeles, Team 3-10, Briggs Fall 2022
CSULA-BRIGGS-F22S3G10
1 membre
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 15
30 derniers jours : 78
Total : 2,173
