Aller au contenu principal
How To Restring a Yo-Yo
Ce dont vous avez besoin
  1. How To Restring a Yo-Yo, String: étape 1, image 1 de 1
    • Unscrew one half of the Yo-Yo from the other by twisting them in opposing directions.
  2. How To Restring a Yo-Yo: étape 2, image 1 de 1
    • Analyze the current state of the string.
    • If the string is worn out, you must determine whether or not you want to put it back in place and keep using the Yo-Yo till the string fully breaks or replace the string right away.
    • If the string is damaged beyond repair, then get your new string ready.
  3. How To Restring a Yo-Yo: étape 3, image 1 de 1
    • Find the end of the string that does not have a knot tied around it. This end of the string is the finger hole.
    • We are not interested in this end. You will know you have the right end if you can smoothly run a finger along the string.
  4. How To Restring a Yo-Yo: étape 4, image 1 de 1
    • Pull at the threading, making a hole that is just big enough to fit onto the ball bearing.
    • Avoid creating a hole that is bigger than necessary, it’s good practice to do so.
  5. How To Restring a Yo-Yo: étape 5, image 1 de 1
    • Place the hole over the bearing, allowing the string to rest on the half of the Yo-Yo with the ball bearing.
  6. How To Restring a Yo-Yo: étape 6, image 1 de 1
    • Hold the half with the ball bearing with one hand and gently tug on the string with your other hand.
    • This will ensure that the placement of the string is secure.
  7. How To Restring a Yo-Yo: étape 7, image 1 de 1
    • Screw the halves back together firmly, making sure that they are aligned correctly.
    • You shouldn't make the halves tighter than 'hand-tight'. This is good for you and the Yo-Yo so you won't have much trouble trying to open it up.
  8. How To Restring a Yo-Yo: étape 8, image 1 de 1
    • Wind up your Yo-Yo and try do a trick to ensure that you’ve done a good job in restringing your Yo-Yo. Now you can enjoy your ‘Yo-Yoing’!
After following these steps, you will have successfully restrung your Yo-Yo.
3 autres ont terminé cette réparation.
Mark Amirthanathan
Membre depuis le 01/19/21
205 Réputation
1 tutoriel rédigé
Équipe
York University, Team S1-G1, Melo-Thaiss Winter 2021 Membre de l'équipe York University, Team S1-G1, Melo-Thaiss Winter 2021
YORK-MELO-THAISS-W21S1G1
1 membre
2 tutoriels rédigés
1 commentaire de tutoriel
nice tutorial
sdsdsds - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 16
30 derniers jours : 46
Total : 5,052
