Aller au contenu principal
Cette vue éclatée est en cours – Recharger périodiquement pour voir les derniers changements !
Ce dont vous avez besoin
Vidéo d'introduction
  1. How To Tear Down Samsung Galaxy S6 Edge Plus, Remove the SIM card tray.: étape 1, image 1 de 1
    • Power off the Galaxy S6 Edge Plus and remove the SIM card tray.
  2. How To Tear Down Samsung Galaxy S6 Edge Plus, Remove the back  cover.: étape 2, image 1 de 3 How To Tear Down Samsung Galaxy S6 Edge Plus, Remove the back  cover.: étape 2, image 2 de 3 How To Tear Down Samsung Galaxy S6 Edge Plus, Remove the back  cover.: étape 2, image 3 de 3
    • Heat up to soften the adhesive around the back cover.
    • Pull up a gap to insert the prying tool and a poker card.
    • Run the poker card and case opening tool around the edges to separate the back cover.
  3. How To Tear Down Samsung Galaxy S6 Edge Plus, Release the rear housing.: étape 3, image 1 de 2 How To Tear Down Samsung Galaxy S6 Edge Plus, Release the rear housing.: étape 3, image 2 de 2
    • Undo the 18 screws in the rear housing.
    • Pull up the rear housing from LCD assembly with frame.
  4. How To Tear Down Samsung Galaxy S6 Edge Plus, Release the motherboard.: étape 4, image 1 de 3 How To Tear Down Samsung Galaxy S6 Edge Plus, Release the motherboard.: étape 4, image 2 de 3 How To Tear Down Samsung Galaxy S6 Edge Plus, Release the motherboard.: étape 4, image 3 de 3
    • Pry up the screen flex connector, battery flex connector, ear speaker flex connector and proximity sensor flex connector.
    • Pry up the motherboard and turn it upside down to release the connector behind.
    • Pry up the connectors on the motherboard to release the front facing and rear facing camera if necessary.
  5. How To Tear Down Samsung Galaxy S6 Edge Plus, Release the battery. (Be extremely patient and gentle.): étape 5, image 1 de 3 How To Tear Down Samsung Galaxy S6 Edge Plus, Release the battery. (Be extremely patient and gentle.): étape 5, image 2 de 3 How To Tear Down Samsung Galaxy S6 Edge Plus, Release the battery. (Be extremely patient and gentle.): étape 5, image 3 de 3
    • Pry up around the edges of battery as there're two main adhesive sticker underneath.
    • Insert the Spudger to pry up the adhesive.
    • Tear the battery by hands.
  6. How To Tear Down Samsung Galaxy S6 Edge Plus, Release the small parts assembled in the front frame.: étape 6, image 1 de 3 How To Tear Down Samsung Galaxy S6 Edge Plus, Release the small parts assembled in the front frame.: étape 6, image 2 de 3 How To Tear Down Samsung Galaxy S6 Edge Plus, Release the small parts assembled in the front frame.: étape 6, image 3 de 3
    • Pry up to release the proximity sensor module.
    • Pry up to release the ear speaker.
    • Pry up to release the vibrating motor.
  7. How To Tear Down Samsung Galaxy S6 Edge Plus, Galaxy S6 Edge Plus charging port assembly.: étape 7, image 1 de 1
    • As stated by the video, the charging port flex ribbon assembly cannot be removed until the front glass is torn down as it’s assembled with the navigator flex in between the glass and LCD.
Mandy
Membre depuis le 12/05/14
9 518 Réputation
9 tutoriels rédigés
17 commentaires
Hi there.
Is this a good way to replace the frame around the camera? I dropped it and chipped it slightly and since the phone is less than 2 months old for me, it is kind of bothering me.
I guess my main concern is, once I do this, is it going to go back together as good as new? I'll probably only need to remove the back cover yeah?
Thanks in advance!
Luke Carr - Réponse
hello, you will need to remove the back cover glass b4 you replace the camera lens and holder. replace processing is simple a hot air gun will help a lot.
check here: https://www.amazon.com/dp/B01M3PL8E8
ggmall -
Great video! Thank you for your time to help us out!
Bob Zak - Réponse
Every one of these I have seen has a lot of adhesive near the home button which makes the screen coming out much harder then any video or tutorial I have seen online showing.
Jody Billings - Réponse
anybody have measurements on the battery ceiling? Does this model have similar issues as the note 7 with no padding to account for battery expansion?
Noah - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 9
Total : 56,717
