Aller au contenu principal
How do I replace the wheels on my Tobago trolley?
Ce dont vous avez besoin
  1. How do I replace the wheels on my Tobago trolley?, Wheels: étape 1, image 1 de 3 How do I replace the wheels on my Tobago trolley?, Wheels: étape 1, image 2 de 3 How do I replace the wheels on my Tobago trolley?, Wheels: étape 1, image 3 de 3
    • Open the trolley and unzip the lining.
  2. How do I replace the wheels on my Tobago trolley?: étape 2, image 1 de 2 How do I replace the wheels on my Tobago trolley?: étape 2, image 2 de 2
    • Unscrew the 4 marked screws with a Phillips screwdriver.
    • When attaching the new wheels, take care not to over tighten the screws.
    • Use the flat-blade screwdriver to remove the 2 washers.
    • Removing the wheelhouse from the trolley.
    • Pinch off the two remaining rivets with the tongs.
  3. How do I replace the wheels on my Tobago trolley?: étape 6, image 1 de 3 How do I replace the wheels on my Tobago trolley?: étape 6, image 2 de 3 How do I replace the wheels on my Tobago trolley?: étape 6, image 3 de 3
    • Remove the other 2 rivets on the outside of the trolley using the flat-blade screwdriver. Then remove the wheelhouse from the trolley.
    • When attaching the new wheelhouse, take care not to over tighten the screws.
Follow the instructions in reverse order to finish the repair.
VAUDE Reparaturteam
Membre depuis le 02/22/16
6 255 Réputation
32 tutoriels rédigés
Équipe
Vaudesport Membre de l'équipe Vaudesport
Community
3 membres
96 tutoriels rédigés
3 commentaires
Dear Vaude, I have a Module 60 where the airline has managed to snap of a wheel recently. I am in contact with the UK supplier of Vaude parts, but is the repair similar to above and therefore I need to order the right hand side plastic/wheel? Thank you for any help.
JANE D - Réponse
Dear Jane, yes, you can use this repair guide also for your Module Trolley. You will get a set of wheels, you so can change both if you want.
VAUDE Reparaturteam -
Dear Vaude
I have a trolley Samoa, and it seems I can't get replacements like for the Tobago. Any idea how I could find wheels to replace the broken ones?
Rollo Launche - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 10
30 derniers jours : 79
Total : 4,700
