Introduction
The boot circuit can be regarded as logic board trigger circuit. To have the phone turned on, working conditions like power supply, clock signal and reset signal are indispensable. What’s more, CPU has to get key components into power-on self-test process and get the bootstrap imported. Since there are so many components involved in the process, reasons for won’t turn on of the phone can also be various.
Vidéo d'introduction
U1000, CPU
This chip is the most important chip on the motherboard. As the central processing unit, It works just like our brain to control every part of our body. So it is responsible for overall control of the phone.
U2600, NAND. It stores data needed for the boot process.
U3300, Charging IC. It converts battery power supply into main power supply.
J3200, battery connector. It makes possible the connection between the battery and the motherboard.
U3100, boost IC. It converts voltage when necessary.
For a detailed explanation of the boot circuit, you can check out the video here.
- How to Fix iPhone 7 No Service
- How to Fix iPhone 7 Hey Siri Not Working
- iPhone 7 Plus Touch ID Not Working – Broken Home Button Cable Repair
- How to Fix iPhone 7 Rear Camera Keeps Shaking
- How to Fix iPhone 7 Plus Half Backlight
- How to Fix iPhone 7 Plus Won't Turn On After Water Damage
- iPhone 6 Won't Turn On - Water Damage Repair
- How to Fix Samsung S7 edge Won't Turn on - Logic Board Solution
3 autre(s) ont terminé cette réparation.
