Aller au contenu principal
How to Access the Internal Components of an HP 15-R011DX
Ce dont vous avez besoin
  1. How to Access the Internal Components of an HP 15-R011DX, Battery: étape 1, image 1 de 2 How to Access the Internal Components of an HP 15-R011DX, Battery: étape 1, image 2 de 2
    • Slide the lock mechanism on the left side of the laptop to the right.
  2. How to Access the Internal Components of an HP 15-R011DX: étape 2, image 1 de 1
    • While holding the right slide mechanism, remove the battery from the laptop.
    • The battery is not pictured here because it is missing from this particular device.
  3. How to Access the Internal Components of an HP 15-R011DX, How to Access the Internal Components of an HP 15-R011DX: étape 3, image 1 de 2 How to Access the Internal Components of an HP 15-R011DX, How to Access the Internal Components of an HP 15-R011DX: étape 3, image 2 de 2
    • Flip the laptop over to reveal screw locations.
    • Use a metal spudger to remove the two rear rubber feet. There are screws hidden underneath them.
  4. How to Access the Internal Components of an HP 15-R011DX: étape 4, image 1 de 2 How to Access the Internal Components of an HP 15-R011DX: étape 4, image 2 de 2
    • Remove the twelve 5mm Phillips #1 screws on the back of the laptop.
  5. How to Access the Internal Components of an HP 15-R011DX: étape 5, image 1 de 2 How to Access the Internal Components of an HP 15-R011DX: étape 5, image 2 de 2
    • Remove the DVD drive from the laptop.
    • Remove the two 3 mm Phillips #1 screws underneath the DVD drive.
  6. How to Access the Internal Components of an HP 15-R011DX: étape 6, image 1 de 3 How to Access the Internal Components of an HP 15-R011DX: étape 6, image 2 de 3 How to Access the Internal Components of an HP 15-R011DX: étape 6, image 3 de 3
    • Flip the laptop and open.
    • Detach the keyboard by prying it free from the laptop using a spudger.
    • Do not completely remove the keyboard yet. It is still attached by a ribbon cable.
    • Disconnect the keyboard ribbon cable.
  7. How to Access the Internal Components of an HP 15-R011DX: étape 7, image 1 de 2 How to Access the Internal Components of an HP 15-R011DX: étape 7, image 2 de 2
    • Disconnect the two narrow ribbon cables to the left of the keyboard connection.
    • Remove five 4 mm Phillips #1 screws from the metal tray for the keyboard.
    • Pry open the plastic casing using a spudger.
    • If struggling to remove the plastic case, check that all screws have been removed.
2 autres ont terminé cette réparation.
Ethan Guillotte
Membre depuis le 03/20/19
490 Réputation
3 tutoriels rédigés
Équipe
UMass Dartmouth, Team S2-G4, Bailey Spring 2019 Membre de l'équipe UMass Dartmouth, Team S2-G4, Bailey Spring 2019
UMASSD-BAILEY-S19S2G4
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 7
30 derniers jours : 18
Total : 500
