Aller au contenu principal
Pour réparer ensemble - Je crée un compte
How to Add a Hole to a Belt
Ce dont vous avez besoin
    1. How to Add a Hole to a Belt, How to Add a Hole to a Belt: étape 1, image 1 de 1
      • Wrap the belt around yourself.
      • Mark with a pen, pencil, or marker where the hole should be placed.
      Demander à FixBot
      Ajouter un commentaire
    2. How to Add a Hole to a Belt: étape 2, image 1 de 2 How to Add a Hole to a Belt: étape 2, image 2 de 2
      • Use a tape measure to center the hole in the middle of the belt.
      • Make sure the hole is in line with the previous hole as well.
      Demander à FixBot
    3. How to Add a Hole to a Belt: étape 3, image 1 de 1
      • Grab a hand drill with a circular bit similar to the size of the current belt holes.
      • For reference, a 5/32 bit was used here.
      Demander à FixBot
    4. How to Add a Hole to a Belt: étape 4, image 1 de 2 How to Add a Hole to a Belt: étape 4, image 2 de 2
      • Place the belt over a scrap piece of wood or on a material that can be drilled on.
      Demander à FixBot
    5. How to Add a Hole to a Belt: étape 5, image 1 de 2 How to Add a Hole to a Belt: étape 5, image 2 de 2
      • Drill all the way through the belt where it has been marked.
      Demander à FixBot
    6. How to Add a Hole to a Belt: étape 6, image 1 de 2 How to Add a Hole to a Belt: étape 6, image 2 de 2
      • Move the drill up and down a few times in place to ensure the hole is smooth around the edges.
      • Be sure the belt buckle fits in the new hole.
      Demander à FixBot
After you complete the final step to your liking the fix is done.
Alexa Velazquez
Membre depuis le 03/22/21
160 Réputation
1 tutoriel rédigé
Équipe
UMass Dartmouth, Team S1-G25, Sinclaire Spring 2021 Membre de l'équipe UMass Dartmouth, Team S1-G25, Sinclaire Spring 2021
UMASSD-SINCLAIRE-S21S1G25
1 membre
11 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 13
30 derniers jours : 102
Total : 3,195
