Aller au contenu principal
How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes
Ce dont vous avez besoin
  1. How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes, How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes: étape 1, image 1 de 1
    • You will see a cable attached to an Allen bolt.
  2. How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes: étape 2, image 1 de 1
    • Loosen up the bolt with the help of Hex key set.
  3. How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes: étape 3, image 1 de 2 How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes: étape 3, image 2 de 2
    • Now, pull the cable as much as you can.
  4. How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes: étape 4, image 1 de 1
    • Tighten up the bolt while you keep pulling the cable.
  5. How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes: étape 5, image 1 de 2 How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes: étape 5, image 2 de 2
    • To center the caliper for a smooth breaking experience, loosen up the two bolts of the brake situated at top and at bottom.
  6. How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes: étape 6, image 1 de 1
    • Now, put the brake on.
  7. How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes: étape 7, image 1 de 3 How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes: étape 7, image 2 de 3 How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes: étape 7, image 3 de 3
    • While putting the brake on, tighten up both the bolts.
    • You are finished adjusting the brakes!
Ligne d'arrivée
2 autres ont terminé cette réparation.
Md Abdullah
Membre depuis le 07/03/21
201 Réputation
1 tutoriel rédigé
Équipe
York University, Team S2-G3, Melo-Thaiss Summer 2021 Membre de l'équipe York University, Team S2-G3, Melo-Thaiss Summer 2021
YORK-MELO-THAISS-SU21S2G3
1 membre
1 tutoriel rédigé
Un commentaire
Dude, the cable is attached incorrectly. The cable routes up and over the little arm.
Grandy - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 11
7 derniers jours : 41
30 derniers jours : 210
Total : 4,358
