Introduction
In this guide we will demonstrate how to align your headlights properly on my 2002 Chevy Tahoe. This is a relatively easy fix even if you have very little experience with repairing vehicles. This should take anywhere between 15 to 35 minutes. You will need a relatively large area so that you can back your car up safely and without worry. If you are unfamiliar with this repair I would recommend wearing gloves due to the fact that your hands and fingers will be exposed to metal within the engine bay and just for overall safety.
Ce dont vous avez besoin
Park your car in front of a vertical wall and make sure it is on a flat surface.
Locate the adjusting screws on the housing for each light; the exact location of each screw varies by make and model, though every model works essentially the same way. One screw is for up/down adjustment, the other for left/right adjustment. You usually have to pop the hood to access them.
To align your headlights follow these steps in the exact order, depending on what vehicle you have the tools listed will help you align your headlights.
