Aller au contenu principal
How to Change Broken Buttons on your Lexus Key Fob
  1. How to Change Broken Buttons on your Lexus Key Fob, Broken Buttons: étape 1, image 1 de 2 How to Change Broken Buttons on your Lexus Key Fob, Broken Buttons: étape 1, image 2 de 2
    • Place the key fob with the removable metal key facing towards you.
  2. How to Change Broken Buttons on your Lexus Key Fob: étape 2, image 1 de 3 How to Change Broken Buttons on your Lexus Key Fob: étape 2, image 2 de 3 How to Change Broken Buttons on your Lexus Key Fob: étape 2, image 3 de 3
    • With the button side facing you, pull the metal latch down towards you to pull out the key.
  3. How to Change Broken Buttons on your Lexus Key Fob: étape 3, image 1 de 3 How to Change Broken Buttons on your Lexus Key Fob: étape 3, image 2 de 3 How to Change Broken Buttons on your Lexus Key Fob: étape 3, image 3 de 3
    • With the exposed corner facing you, place the metal key into the slot.
    • Turn the key sideways to open the key fob.
    • You may feel like you're breaking the key fob, but be firm while twisting.
  4. How to Change Broken Buttons on your Lexus Key Fob: étape 4, image 1 de 2 How to Change Broken Buttons on your Lexus Key Fob: étape 4, image 2 de 2
    • Remove the motherboard and battery to access the buttons.
  5. How to Change Broken Buttons on your Lexus Key Fob: étape 5, image 1 de 3 How to Change Broken Buttons on your Lexus Key Fob: étape 5, image 2 de 3 How to Change Broken Buttons on your Lexus Key Fob: étape 5, image 3 de 3
    • Rotate the front plate, the broken buttons should fall out with ease.
    • Replace the broken buttons as necessary.
To reassemble your device, follow these instructions in reverse order. Apply firm pressure when snapping the front and back covers together.
7 autres ont terminé cette réparation.
Michael Tan
Membre depuis le 01/08/15
587 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 30-3, Green Spring 2015 Membre de l'équipe Cal Poly, Team 30-3, Green Spring 2015
CPSU-GREEN-S15S30G3
4 membres
10 tutoriels rédigés
Un commentaire
useless guide
Davide - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 16
30 derniers jours : 50
Total : 6,270
