Aller au contenu principal
How to Change to 12V Power Supply
Ce dont vous avez besoin
    • Remove the modem so only the open-storm board remains. This is to prevent accidentally frying the modem.
    • Remove the JP1 and JP2 jumpers
    • Plug in the 12V power source
    • Using a multimeter, touch the ground to any of the ground pinouts on the board and measure the JP1 and JP2 jumpers
    • You should see 12V on the middle and bottom pin of JP1 and 12V on the bottom pin of JP2. The top pin of JP2 should be ~ 3.6V
    • If ~ 3.6 V measured on top JP2 jumper, then add jumper in new position.
    • JP2 powers the modem so it's very important that it is not supplied the higher voltage, otherwise the modem will fry.
    • Plug in the 12V power supply again and see if the JP2 jumper measures ~ 3.7V
    • Unplug the power source and plug in the modem.
    • Be vary careful to not skip a modem pin when plugging in and that it is oriented in the correct direction.
    • Power back on the board and wait to see a green light on the modem (indicating that it is properly powered and trying to connect to the internet).
To revert back to 3.7V power, flip back the 2 jumpers to how they were at the start of the guide.
Meagan Tobias
Membre depuis le 01/29/19
154 Réputation
1 tutoriel rédigé
Équipe
Open-Storm Membre de l'équipe Open-Storm
Community
14 membres
24 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 64
