Introduction
Have you ever had sticky keys or a defective keyboard for your LG Neon II? If the answer is yes, then it is most likely because of your keyboard being too dirty. In this simple guide, you can follow 7 steps to help solve your problem and make your keyboard easier to use.
Ce dont vous avez besoin
To gain access to the phone’s speaker, grip the phone firmly in an inverted position with the back of the unit facing up and the LG insignia positioned away from you.
Using both hands as support, use your thumbs to gently guide the rear housing away and in the direction of the arrow.
To separate the button board/circuit module from the phone main frame, firmly, but gently, unscrew (counter-clockwise) the seven outside 4 mm screws along the rear outside rim of the main body.
Using the plastic opening tool, gently pry the circuit board from the phone.
The partially separated circuit board may be attached to the main button area by factory adhesive/tape. If so, use a soft padded surface to rest the mother board on. Your work area will still be accessible without separating the two units.
Use a brush or a soft cloth to gently clean the keyboard keys of any debris or contaminants.
Use a brush or soft cloth to gently clean the silver keyboard buttons.
To reassemble your device, follow these steps in reverse order.
