Aller au contenu principal
Pour réparer ensemble - Je crée un compte
How to Clean a Robotic Vacuum Cleaner
Ce dont vous avez besoin
    • Turn off the vacuum and remove it from the charging dock.
    • Open the dustbin compartment and remove the bin.
    • Dump all debris into the trash.
    • Remove the filter from the dustbin.
    • Rinse the dustbin if it's washable (check your model's manual)
    • Tap the filter gently to dislodge dust or use a nylon brush.
    • Replace the filter if it’s too dirty or damaged. Some filters are washable but still need replacement after a few washes.
    • Do not rinse the filter unless it's labeled washable.
    • Make sure that both filter and dustbin are completely dry before reinstalling to prevent mold.
  1. Outil utilisé dans cette étape :
    Utility Scissors
    $5.59
    • Remove the main roller brush from its housing.
    • Cut away tangled hair with scissors.
    • Avoid cutting into the bristles or otherwise damaging the brush.
    • Unscrew or pull out side brushes if removable.
    • Wipe them with a damp cloth to remove buildup.
    • Check for bent or damaged bristles and replace the side brush if needed.
  2. Outil utilisé dans cette étape :
    Microfiber Cleaning Cloths
    $3.99
  3. Outil utilisé dans cette étape :
    Metal Spudger
    $2.99
    • Remove debris stuck around the wheels and caster.
    • Use a spudger to gently pry off the front caster wheel.
    • Pull out any hair or debris wrapped around the caster axle.
    • Spin them manually to check for smooth motion.
    • Avoid forcing parts—check your manual for disassembly.
    • Reinsert the filter, brush, and dustbin securely.
    • Power on the vacuum and run a short cleaning cycle.
    • Listen for unusual sounds that could indicate issues.
    • Don’t run the vacuum if anything feels loose or jammed.
Now that everything’s cleaned and reassembled, your vacuum is ready to get back to work.
Sebastian
Membre depuis le 08/19/18
33 106 Réputation
72 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 13
30 derniers jours : 13
Total : 40
